The ABS pump will weight in the region of 2Kg, plus a few lines less, and a few ml of fluid less... Might get near 3Kg saved.
JJJ had a thread a while back asking about removal, I stuck a load of info in there about getting a speed signal to the dash from an ABS sensor etc. I cant be fcuked to search to find it because its of no use to me
I wiil have a look, thanks!
If you remove your ABS try insuring you car with it as a declared mod, I wish you the very best of luck but AFAIK there is not a single company that will cover you.
i live in greece so no problem
