Also got carried away and should of taken more photos.
First jack it up or use a 4 poster ramp
Then remove the undertray, if you cant manage these 2 jobs, go no further.
You should see the sump looking like this
First drain the oil, yours going to get loads of it in your hair anyway but you dont want 4 litres of the stuff.
Then remove the lower sump, about 15 bolts, and it'll drop down. Undo the 2 bolts holding the sensor in the lower sump and leave the sensor hanging.
Remove the next stage of the sump now.
This is quite fiddley as the exhaust gets well in the way. Especially if its a 3" one.
Theres an electrical plug above where sensor dangles and some of the bolts are horizontal aswell as vertical.
I ended up removing the downpipe from the turbo and it gave me some extra room.
Bigger bit removed
Then remove the oil pickup pipe. 4 bolts.
Then remove the bolts that hold the balencer shafts on.
It should then look like this. Apologises for the photos
