Fitted A New Heater Over The Winter
t7 heater
1 reply to this topic
#1 StevieD
StevieD
  • 10 posts
  • Interests:Cars, hiking & travel, DIY, photography, most sports.
Posted 15 February 2026 - 10:11 PM
Having bought my VXT towards the end of the summer last year, I realised fitting a new heater would be a priority if I ever wanted to go out for a drive on a nice cold and crispy morning.  I bought a new T7 heater just before year end and finally after a few weeks got my head in the right place to install it.  I knew it probably wasn't going to be the easiest job to start with on the car but it had to be done.  I'd read many of the guides and comments on the site about it so was reasonably prepared.   I'd like to say a big thanks to all those people over the years who have contributed to the guides & tutorials - all really helpful.  I'd also like to thank all those people (I appreciate at least some of them may no longer being using the site) who helped with the design and testing for what is now the latest iteration of the T7 heater.  Very well designed and well made piece of kit and electrics are fully plug n' play now too.
A few things to note from my experience,
- getting the old one out was a real PITA. I ended (as others have reported) breaking it up into 2 parts in-situ, before actually removing it.  Lots of blood, sweat and tears.
- I found removing the vacuum hose from the brake servo helpful to clear the path.
- I also found removing some of the bonnet catch assembly and electrical connector was also helpful in make a bit more space.
- Also tips about getting a strap under the battery and taking it out tipped up was helpful as well.
- The new one one fitted in pretty easily, just had a to shorten the existing heating circuit hose on the return side a bit.
- I had to fit the supplied bowden cable, I couldn't reuse the existing one although I'd read some people had managed this - not sure how?  Mine was way too short as it has to be fed from the driver side to go through the clamp and fit over the valve control on the new unit. That meant I had to remove the dashboard which as it turned out was a bit tricky and probably took longer than anything else.
- It turned out the front dash facia had been stuck into place with some type of butyl tape all the way around, it did eventually come off but left a really mess on both sides.  It took me an age to remove all the residue and I realised re-fixing it with velcro would be a much better solution.
- Then came my biggest surprise I'd removed the 3 screws for the top dashboard, one from beneath the light cluster then two from the other side but the dashboard was still firmly attached on the passenger side corner.  Eventually I found another (a 4th fixing point with screw) directly behind the VX220 badge, I just couldn't reach it with anything.  I ended up drilling out the rivets which fixed the badge in place to the frame, once that was removed I could see the fourth mounting point with screw, once this was taken out the dash came away fine.
- With the dashboard now removed from the car I could now clearly see what had been done, although i've no idea why.  A previous owner in the lifetime of the car must have fitted a 4th aluminium bracket, very well made and looked like it was an original part of the car until more closely inspected and I realised that it had been riveted in place.  Very odd.
- After that it was all plain sailing, fitted the bowden cable at the control end and then put everything back.
- I decided to mount the VX220 badge to the underside of the fascia so that I could always get access to this 4th mounting point although I could probably have removed that anyway as I still can't figure out why it was put there.
Finally had a dry day and took the car out for a proper test of the heater, really did perform well and made a big difference.  Just a shame the weather has been so wet recently, I'd probably been better off installing a snorkel.!!!  :D
Just trying to decide on the next job, hopefully something a bit simpler.  My wrist and knuckles are still healing.
Looking forward to getting out for some more driving, if it ever stops raining.
Steve.
#2 Arno
Arno
  • 1,269 posts
Posted 18 February 2026 - 06:54 AM
The VX dash tops do have a bit of a habit of warping and creating a gap towards the ends so the previous owner may have added the extra mounting point to pull it down more evenly?
Also tagged with one or more of these keywords: t7, heater
