Posted 21 May 2026 - 07:15 PM
Posted 21 May 2026 - 08:14 PM
The GM Ecotec platform is quite popular for stock cars in the US, so there might be some help there.
https://www.bkracing.shop/s/shop
https://www.facebook...onwaterstuning/
https://www.instagra...unkworksporting
https://www.instagra...nkworksporting/
Although for most part, an engine is an engine.
Get some good head work done, decent cams, intake, exhaust, etc etc All basic tuning stuff. Although n/a tuning is often futile and offers very poor return for the money spent.
You could opt for a 2.4 setup, and with a bore to 87mm could maybe get closer to 2.5. But you might not achieve that on a Z22se block, but you could just opt for a newer 2.4 bottom end.
For head work and general engine work in Europe, Veicomer in Portugal do decent work.
https://www.instagram.com/veicomerv/
Closer to home, maybe some people here could advise
https://www.speedste...forum/index.php
Old UK forum, you might find something there
https://z22se.co.uk/
https://www.vx220.or...0-16-years-old/
Edited by stevieturbo, 21 May 2026 - 08:15 PM.
Posted 21 May 2026 - 08:39 PM
Posted 22 May 2026 - 05:16 AM
Posted 22 May 2026 - 07:03 AM
Posted 22 May 2026 - 08:10 AM
Posted 22 May 2026 - 08:36 AM
Posted 22 May 2026 - 11:48 AM
Posted 25 May 2026 - 06:29 AM
Posted 31 May 2026 - 10:37 PM
https://www.vx220.or...ton-comparison/
Notice that the Z22YH pistons have keystone-style gudgeon pin bosses and not parallel gudgeon pin bosses like the Z22se pistons.
That means you will need to use the Z22YH rods if you choose those pistons, as nobody seems to make forged Z22YH rods.
Even later on in the race and performance programs in the US, GM did not appear to use the keystone-style after the Z22YH's introduction and continued with Eagle (most builds) and Manley (big power, Ethanol etc. builds) parallel types.
You can see some headwork here:
https://www.vx220.or...-pre-reshaping/
A short chain and balancer delete would also help:
https://www.vx220.or...mp-short-chain/
Weight saving, lower drag alternator?
https://www.vx220.or...tor-on-a-z22se/
Posted 01 June 2026 - 07:59 AM
Posted 06 June 2026 - 09:18 PM
Forgive me if I am misinterpreting you, but you couldn't fit YH pistons onto forged H beam SE rods as the YH pin bosses are a. closer together and b.keystoned, at least not without making scary modifications to the rods taking away a lot of metal on the small end.
Have a look at the measurements in the last photos of the second post:
https://www.vx220.or...ton-comparison/ 32mm for the SE and 29mm at it's widest for the YH (not accounting for clearances on either)
You might just get away with it as, taper notwithstanding, you only need to lose 1.5mm each side of the pin hole near the H section but i'm more in favour of custom pistons by the time you would do that and then need to modify the YH pistons too.
Rod photo here:
https://www.eaglerod...951&brand=24810
Edited by blackoctagon, 06 June 2026 - 09:18 PM.
Posted 07 June 2026 - 08:26 AM
Also tagged with one or more of these keywords: z22se, na
General Discussion →
Tuning & Modifications →
High Na BuildStarted by gilles , 21 May 2026 |
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Leamington SpaStarted by Jordang , 22 Aug 2020 |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 |
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 |
