The Quest For Torque
Posted 04 December 2006 - 03:31 PM
Posted 04 December 2006 - 05:24 PM
Posted 04 December 2006 - 05:38 PM
You'll have to host them on a hosting site, e.g. photobucket.comSorry. The system does not seem to want me to add even the smallest jpeg so looks like you'll have to do without the pix.
Posted 04 December 2006 - 06:35 PM
Posted 04 December 2006 - 06:49 PM
Posted 04 December 2006 - 06:59 PM
Posted 04 December 2006 - 08:34 PM
My journey into the unknown in a quest for lots of torques (whatever they are) begins. Given the long-stroke nature of the 2.2 Z22se I've eschewed sky high revs, hot cams and throttle bodies in favour of the blower route. Booked in with Courtenay next week. However, instead of their normal route of fitting the standard vx throttle body I've made up a loom extension (with the wires changed over) and supplied them with a 68mm TB (which is what is supposed to go on the s/c and fits without an adaptor). Apparently they've not used one before with the blower conversion so It'll be interesting to see the results -- hopefully more torks piled on to lots of torks. Rods have been changed for beautifully-made Eagle items (very cheap from the US now with the two dollar pound) and, in the final quest for a further torks, a Tsudo (formerly Weapon R) 4-2-1 manifold. the latter required major surgery by Mr Mig Welder to the downpipe section. In the pix I'm indicating a joint which was badly warped and had to be machined/pressed flat to get a gastight joint on my Tsudo. Hope to be posting the results of all this in a few weeks when I've got the clam back on.
Sweet!
Two questions:
Are you going to run the SC with standard cams?
Is the boost level fixed on that supercharger Courtenay use?
I can host some pics for you if you wish. Email me @ charles_lovell@hotmail.com
Or you can register HERE and create your own Gallery!
Posted 05 December 2006 - 12:16 AM
Posted 05 December 2006 - 12:31 AM
Posted 05 December 2006 - 08:02 AM
As for the other questions: standard cams, Courtenay effectively increase the boost level by fitting a smaller pulley to the blower, there are several U.S. suppliers of Eagle rods if u do a search on e-bay. I think mine came from JBody performace Co Ltd. Rob its a bit of a home brew recipe and the boys at Courtenay have mentioned they are not sure the blower will work well with the Tsudo manifold -- we'll have to see.
Did Courtney recommend the Eagle rods, just thinking if I should get some ordered now
Posted 05 December 2006 - 08:58 AM
Posted 05 December 2006 - 10:10 AM
GM recommend eagle rods, they're good for 600bhp!
Think I deserve a passenger ride for this
Looks fantastic...
Very nice looking! Did you get away with not cutting the boot? Which part is fabbed by you?
Cheers, Paul.
Posted 05 December 2006 - 10:12 AM
Posted 05 December 2006 - 10:23 AM
Posted 05 December 2006 - 10:30 AM
"Which part is fabbed by you?"
Paul, There is not need to make any changes the manifold itself, which comes beautifully TIG welded and should really be hung on the wall as a work of art. However, the downpipe (two into one section) does require major restructing for our application. You can see from the crappy MIG welding that I did that bit. It takes a long time, a lot of swearing/cups of tea and you need a powerful welder. My recommendation would be to farm it out to a professional TIG welder then it would look as good as the manifold. Since Courtenay have some doubts about its suitability with the blower, it would be better for anyone considering the blower option not to order a Tsudo manifold until we see how it works on my car.
Yeah, i remember them saying they lost power with the regal manifold, but i can't help thinking it has to come down to the mapping... More flow has got to equal more power?
Posted 05 December 2006 - 10:48 AM
Posted 05 December 2006 - 11:19 AM
That wasn't a whinge..... or a high horsetheres that high horsey again lol
if you read the thread it states that he knows you dont spec them for your "modifications" but he fitted them because he wanted to....... if its above spec then surely there are no grounds to whinge
Didn't want anyone to think we'd leave in weak components! Sometimes things get misunderstood on a forum...... I now appologise if that was the case.deemed to be adequate
Posted 05 December 2006 - 11:24 AM
