Looks great! The Tsudo is been used on many FI Ecotecs in the US so can't see why it would cause a problem this side of the pond..."Which part is fabbed by you?"
Paul, There is not need to make any changes the manifold itself, which comes beautifully TIG welded and should really be hung on the wall as a work of art. However, the downpipe (two into one section) does require major restructing for our application. You can see from the crappy MIG welding that I did that bit. It takes a long time, a lot of swearing/cups of tea and you need a powerful welder. My recommendation would be to farm it out to a professional TIG welder then it would look as good as the manifold. Since Courtenay have some doubts about its suitability with the blower, it would be better for anyone considering the blower option not to order a Tsudo manifold until we see how it works on my car.
The Quest For Torque
#21
Posted 05 December 2006 - 11:27 AM
#22
Posted 05 December 2006 - 11:40 AM
Yeah, i remember them saying they lost power with the regal manifold, but i can't help thinking it has to come down to the mapping... More flow has got to equal more power?
This was quite a while back now, however if my memory serves me correct the issue it was more down to how it collects and the pulse legths with the compressor equiped car, the Weapon R manifold on paper is not best suited for the same reason, however we are going to try it on Griffo's to see what will happen.
#23
Posted 05 December 2006 - 11:55 AM
Changing rods may well be something for future stages.........Here I was thinking more money to be spent
So with standard rods ect and with not changing the rev limit, any idea what you could get out of this engine and still have an everyday RELIABLE car
With regards to Stage 2 the peak power on the SC conversion is made at the rev limiter and peak power would be more if we increased the rev limit, but we choose not to. We cap the bhp at around the 240 or so mark simply because this is both reliable and durable. Bear in mind there are some 46 conversions done between us and Hitec.
#24
Posted 05 December 2006 - 12:00 PM
Here I was thinking more money to be spent![]()
Thats great I like those words reliable and durable,
Stage 3
#25
Posted 05 December 2006 - 12:20 PM
#26
Posted 05 December 2006 - 01:23 PM
The exhaust manifold that has worked quite well is the dbilas exhaust manifold, however the down side to this is that even more heavy than the standard item so I'm told which is a pity.
Surely, equal length runners is the ideal situation for a manifold, since you minimuse pulse collisions?
Maybe its the cams causing the problem, don't know how much overlap the NA cams run, probably not ideal for a supercharged application...
Ta, Paul.
#27
Posted 05 December 2006 - 01:40 PM
#28
Posted 05 December 2006 - 03:39 PM
This was quite a while back now, however if my memory serves me correct the issue it was more down to how it collects and the pulse legths with the compressor equiped car, the Weapon R manifold on paper is not best suited for the same reason, however we are going to try it on Griffo's to see what will happen.The exhaust manifold that has worked quite well is the dbilas exhaust manifold, however the down side to this is that even more heavy than the standard item so I'm told which is a pity.
Ta, Paul.
It was not the length that was the problem, it was the way it collected, as it is like the OE unit 1& 2 together and 3&4 together the best for a supercharged engine is 1&4 and 2&3 As said this is all on paper, as we have never tried the Weapon R, due to customers not wanting to cut the boot area. However as Mark said we will give it a go, hopefully it will be good.
Edited by Jon, 05 December 2006 - 03:42 PM.
#29
Posted 05 December 2006 - 03:48 PM
Forgive me if i'm asking something a little dumb here (starting to get out of my knowledge comfort zone
Equal length runners means gas takes the same amount of time to get to the collecter from each cylinder, so because each cylinder fires at a different time, you never get any exhaust pulse collisions at the collectors because they slightly out of synch with each other?
Ta, Paul.
#30
Posted 05 December 2006 - 04:21 PM
Forgive me if i'm asking something a little dumb here (starting to get out of my knowledge comfort zone) but i don't see why the way the runners are collected should have any effect on performance:
Equal length runners means gas takes the same amount of time to get to the collecter from each cylinder, so because each cylinder fires at a different time, you never get any exhaust pulse collisions at the collectors because they slightly out of synch with each other?![]()
Ta, Paul.
Blimey Paul you are getting me thinking now....The the engine fires 1342 3&4 are close and 2&1 is close on the firing cycle. Equel runners will of coarse help but if the back pressure in the exhaust is to high then this set up could lead to problems in which case the Weapon R with 1&4 and 2&3 would be better. Its on a small issue, but we are getting close with back pressure on the current range of aftermarket exhausts.
#31
Posted 05 December 2006 - 04:25 PM
Ah yes, back pressure - i'd forgotten about that... I'm guessing the full milltek has the least possible back pressure without removing the cat completely?
Such a shame you can just remove the cat and have a 'special' lean map for the MOT...
#32
Posted 05 December 2006 - 05:55 PM
#33
Posted 06 December 2006 - 05:07 PM
#34
Posted 07 December 2006 - 04:33 PM
#35
Posted 07 December 2006 - 07:31 PM
#36
Posted 11 December 2006 - 10:26 AM
This was quite a while back now, however if my memory serves me correct the issue it was more down to how it collects and the pulse legths with the compressor equiped car, the Weapon R manifold on paper is not best suited for the same reason, however we are going to try it on Griffo's to see what will happen. The exhaust manifold that has worked quite well is the dbilas exhaust manifold, however the down side to this is that even more heavy than the standard item so I'm told which is a pity.
Anyone tried the Regal manifold? just thinking of the weight saving over standard.
From web site
The VX220 product range is growing by the day and the next part is the performance stainless steel high flow manifold. With a 40% weight reduction over the standard parts. This manifold will fit onto the standard system which will increase the perormance of your vehicle.
#37
Posted 17 December 2006 - 11:34 AM
#38
Posted 17 December 2006 - 11:49 AM
http://s117.photobuc...ercharger-1.flv
This is the blower installed:
http://i117.photobuc...rcharger003.jpg
And this is John and Mark (not sure which one is which):
http://i117.photobuc...allation001.jpg
#39
Posted 17 December 2006 - 11:58 AM
If I have managed to do this right this should be a link to a video clip the car car on the dyno. Note the manifold changing colour.
You wern't kidding, that was so funny, I think you may need a LOT,LOT of lagging
Think I may forget about the manifold then.
Maybe Dbilas I think thats cast as well as the standard one maybe a better flow
Edited by NickB777, 17 December 2006 - 12:12 PM.
#40
Posted 17 December 2006 - 02:54 PM
The story so far. The car is back in Cornwall from Courtenay (a bloody long way away) in Norfolk and results look pretty impressive. A smidgin under 240 bhp at @ 6,500 (a bit of a jump from the flacid 147bhp the standard car puts out) and 214 lb ft of torque @ 3,500 rpm
Good to know you got that installed in the end, i'm jelous!
Whats the restriction on the setup atm? Or is it simply time for a smaller pully?
Ta, Paul.
