215bhp Na Power
59 replies to this topic
#1 vocky
Posted 20 August 2007 - 02:19 PM
thought some of you might want an update of my 2.2's mapping :) My vx spent over a week recently going between TMS and Superchips rolling roads to have the 310cc injectors mapped (standard injectors are 252 cc) Picked her up Friday and it seemed pretty good, but never had the time for much driving :( Started her up this morning and the cold tickover was very sweet, infact the best it's ever been since the engine build :D I normally allow the engine to warm up before going for a spin but wanted a cold engine run to check the mapping, very pleased with the results....nice and smooth thumbsup Engine response feels much more progressive with no flat spots, but as soon as the engine hits 4200 rpm the cams let rip all the way to the 6850rpm limiter Imnotworthy In gear acceleration has improved massively, mainly due to the flat spot at 4k rpm vanishing :) Not sure of the final power, I'm not really interested :huh: , but will post the rolling road figure from the last run (which will be later this week) thumbsup I am finally happy with my vx220's performance, so until I fit a 2.4 vvt with itb's that's about it for now :poke: I must thank all those involved in the mapping work, you have done a fantastic job guys :groupjump:
#2 GunnerGibson
GunnerGibson
  • 367 posts
Posted 20 August 2007 - 02:22 PM
if the power is still rising near to the limiter get a 7k raise! the limiter is harsh on these cars... im going to make the lmiter softer when i have it mapped. sounds like you've done some top work... nothing more satisfying when it all comes together. good effort.
#3 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 20 August 2007 - 02:38 PM
Hail vocky! Imnotworthy Imnotworthy What's the product code for the valves you used?
#4 GunnerGibson
GunnerGibson
  • 367 posts
Posted 20 August 2007 - 02:40 PM
i meant to ask....how do you time the cams in on n/a VX? or are they just ground differently and run on standard settings....
#5 ikarl
ikarl
  • 213 posts
Posted 20 August 2007 - 03:22 PM
Imnotworthy
#6 vocky
Posted 20 August 2007 - 03:23 PM
I have piper cams and they peak at 6800rpm so not really worth going higher with the limiter :)
They were very simple to 'time up' because piper kept the standard method of cam chain timing marks thumbsup
I would advise to find a standard size wasted stem valve rather than +1mm, the added cost of fitting them is not worth the gains (£25 per valve seat :o ) but sivalves should be able to supply them :unsure:
si valves
for reference these are my +1mm items
2.2 ECOTEC GM EX STOCK SEV-1707-1
2.2 ECOTEC GM INT STOCK SEV-1706-1
#7 dude
dude
  • 1,404 posts
Posted 20 August 2007 - 04:16 PM
Up with charts :D Still interested in the wheelpower ;)
#8 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 20 August 2007 - 04:44 PM
Not until I'm happy :P
#9 dude
dude
  • 1,404 posts
Posted 20 August 2007 - 05:51 PM
He can´t claim 200hp on the flywheel without telling the actual wheelfigure :P Or is your rr a happy one ;)
#10 Baron Von Scubadaddy
  • 6,645 posts
Posted 20 August 2007 - 06:10 PM
Nice one Vocky I'm looking forward to tunning mine Thank you for all efforts in leading the way to 200hp You da man !! Imnotworthy
#11 vocky
Posted 20 August 2007 - 06:24 PM
I always thought the TMS rolling road read about 10 bhp low with the 2.2 vx's :P
#12 JawZ
JawZ
  • 2,571 posts
Posted 20 August 2007 - 06:43 PM
I've been following your project for a while now over at z22se.co.uk but havn't registered over there ;) Just wanted to let you know that I think your work is really interesting and very nicely done thumbsup Looking forward to see the final results of the mapping :) Make sure you enjoy those extra ponies rallly
Edited by JawZ, 20 August 2007 - 06:44 PM.
#13 Stefan_A
Stefan_A
  • 1,477 posts
  • Interests:Photography, british sports cars, diecast models, GT racing, whiskey, project management
Posted 20 August 2007 - 09:52 PM
Go ahead JawZ, admit that you are tempted to do this mod on your car. Then you can tell the rest of us (and let us have a go at it on the next meeting here in Sweden) :groupjump:
#14 Arno
Arno
  • 1,238 posts
Posted 21 August 2007 - 12:40 PM
Theoretically, correct. In practice I'd suggest setting the rev limiter at 7000 when the horsepower peaks at 6800.
Personal preference, but..
A few hundred rpm over the peak HP is usually a good idea as it keeps you the powerband once you shift up and also gives you a little 'headroom' in the lower gears to shift at/close to the peak hp rpm without slamming into the limiter every time. 50 rpm is a very small margin :)
My engine peaks close to 8100rpm and my limter is set to 8600rpm (it's mapped to 8700rpm). That works fine, but even then I have to be quick in 1st and 2nd gear or it hits the rev limiter.
#15 JawZ
JawZ
  • 2,571 posts
Posted 21 August 2007 - 01:46 PM
Tempted B)
Planning to get some engine mods this winter thumbsup
#16 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 21 August 2007 - 09:15 PM
I'm a fair way behind on all this..... What mods have you done to get this sort of Power Vocky??
#17 vocky
Posted 22 August 2007 - 03:29 PM
wheel figure was about 179 hp :)
torque was 195 Ft Lb's :D
Final rolling road figure 215.0 bhp :groupjump:
#18 luna_s
luna_s
  • 1,934 posts
Posted 22 August 2007 - 04:09 PM
congrats, time to squeeze out that extra 5bhp from somewhere :lol:
#19 JG
JG
  • 13,613 posts
Posted 22 August 2007 - 04:12 PM
well done Vocky.
only 25bhp shy of the charger. Imnotworthy
#20 alanoo
alanoo
  • 1,324 posts
Posted 22 August 2007 - 04:15 PM
Easy one, bigger diameter exhaust line :D
