TAT Pedals
163 replies to this topic
#141 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 16 May 2011 - 08:44 PM
I've got a nut here and it happily swivels in a 6mm socket I'll try to get a photo against a ruler....
#142 jules_s
jules_s
  • 15,275 posts
Posted 16 May 2011 - 09:06 PM
Nope from what i gather that's £1.10+VAT PER rubber bung (or £1.39+VAT from the local stealer)!!!!! So nearly the cost of the pedals to replace all the rubber bits.
I managed with a 6mm socket, but agree with you it's a smidge smaller. But luckily managed to do the job. Mind you my pedals have only done 60k miles so weren't too bad.
That is simply fcuking crazy thumbsdown
Anyways, eyeballing the nut I'd say it was about 5.25mm ish...annoyingly too big for a 5mm socket but miles too small for a 6mm. Not the best pic in the world as its cropped but I think it shows how small my nuts are :rolleyes:
Im sensing some Lotus gimp ordered some arse sized nuts here. Like I said Im going to be buying some nylock wing nuts for peeps on here with the same issue :rolleyes:
#143 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 17 May 2011 - 08:41 AM
Thanks Christ for that, I have the same issue as Jules and didn't want to look daft as I couldn't get a 6mm spanner or socket to fit. If you suss it out, can I borrow your solution?
#144 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 17 May 2011 - 08:53 AM
Is it an Imperial size?? Surely not.
#145 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 17 May 2011 - 09:03 AM
Unlikely. Jules has tried a couple of imperial sockets to no avail.
On that subject, if we have imperial sockets, why can we not have rebellion sockets which are kind of the opposite size.
#146 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 17 May 2011 - 09:35 AM
If I had a car I would try to fit mine, sounds like fun better do it before I fit the steering wheel back on, might be a bit easier to get in there.
#147 jules_s
jules_s
  • 15,275 posts
Needle nose pliers and wing nuts are where I'm heading ;)
#148 Muttley
Muttley
  • 530 posts
Posted 17 May 2011 - 09:42 AM
Mine were fitted with either a 5 or 6mm socket. To make them fit easier, I put 2 nuts in the socket, then screwed till the first nut clasped the bolt (hope this makes sense!!!!!!!) Steve
Edited by Muttley, 17 May 2011 - 09:44 AM.
#149 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 17 May 2011 - 11:23 AM
wouldnt just a blob of sillicon sealer do the trick instead of replacing the bungs? -i have a new fond love for this stuff as it seems to keep coming in useful. :)
#150 The Batman
Posted 17 May 2011 - 11:29 AM
watching jimmy do it this week, made me confirmed i will NEED it but first i need to cut my willy off so i can multitask :lol:
#151 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 17 May 2011 - 11:44 AM
You have a willy? :saw:
#152 PaulCP
PaulCP
  • 6,066 posts
Posted 17 May 2011 - 12:28 PM
If you're having withdrawal symptoms feel free to go to where mine's in storage and fit the set you're holding for me :rolleyes:
#153 jules_s
jules_s
  • 15,275 posts
Posted 18 May 2011 - 07:08 PM
I managed to source some replacement nuts/bolts today, and i think I can see why a few of mine need drilling out :rolleyes:
New bolts/wingnuts:
Comparison between heads...and this was one of them that I managed to get out!
They cost 50p each, apparently vaux charge 68p for the black VXR bolts alone. TBH I think the bloke just plucked that figure out of the air and the £5 went in his back pocket :rolleyes:
Hopefully they fit, if not i'll have to revert back to the nylocks thumbsup
#154 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 20 May 2011 - 04:57 PM
7/32 socket fits very nicelyPosted Image
Edited by Sticky, 20 May 2011 - 04:58 PM.
#155 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,863 posts
  • Interests:Big baps.
Posted 21 May 2011 - 01:31 PM
Fitted mine today. Not a difficult job. 5.5mm socket worked fine. Upside down in the footwell was the hardest part. The grommets weren't difficult to fit, just a bit fiddly. I couldn't fit the bit of plastic that goes in the grommets hole. They just fired out again, or if I pushed them harder they pushed the grommet out of its hole. Anyway, I don't think they're needed as they seem to stay in place. Initial driving impressions...easier to heel and toe than the standard, and more to the point easier to brake harder while blipping. I'm a happy customer.
#156 oblomov
oblomov
    oblomov
  • 3,887 posts
  • Interests:Mumblers
Posted 21 May 2011 - 01:50 PM
5.5mm quarter inch drive socket does it. thumbsup
Edited by oblomov, 21 May 2011 - 01:50 PM.
#157 TATONSPEEDY
TATONSPEEDY
  • 422 posts
  • Interests:Speedster, VX220, Lotus Elise, Lotus Exige, 340R, Catheram, Motorbikes, Mountain bikes, Computer, Web sites
Posted 21 May 2011 - 06:41 PM
Thanks to all and to nick ! B)
#158 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 21 May 2011 - 07:31 PM
Thanks to Taton and to nick ! B)
#159 TATONSPEEDY
TATONSPEEDY
  • 422 posts
Posted 04 May 2025 - 04:14 PM
Hi there, I could remanufacture some Throttle pedal (hard colorless anodized like OEM), tell me if interrested
Edited by TATONSPEEDY, 04 May 2025 - 04:14 PM.
#160 Baron Von Scubadaddy
  • 6,645 posts
Posted 11 May 2025 - 10:02 PM
yeah I'll have some of them please Tat
