Engine Warning Light Problem
Posted 07 June 2004 - 07:24 PM
Posted 07 June 2004 - 08:45 PM
so I reset the ECU (ignition on and off 15 times)
Does this work? I've heard of all sorts of different ways to reset the ECU.
The other thing that puzzles me is, When i turn the ignition on the temp gauge reads 1 temp then drops the the normal temp it alsos show when running, does any 1 else have this as i cant see it mentioned in the owners manual??
Mine does this but i've not really been concerned about it. Should i be?
Posted 07 June 2004 - 09:32 PM
Posted 07 June 2004 - 09:39 PM
Posted 07 June 2004 - 09:58 PM
To reset the ECU you simply have to remove fuse nbr 8 (7,5A) for a few minutes and reinsert it. The ECU will be back to normal operating mode and the ECU-warning light will be out. Keep in mind that the above mentionned operation will NOT solve the initial fault which triggered the ECU-error mode, and also will delete all fault-messages from the ECU-memory. So there will be nothing to read out on their computer by the dealer afterwards. Well, not untill the error reproduces itselves in which case a new error-message will be stored in the ECU-memory and the ECU-warning light will come on again.There are two ways to "reset" the ecu that i know that definately work.
one is to disconnect the battery for an hour or so and the other one is to take a fuse out, not sure which one but may be no 12, i have tried both and they work.
Posted 08 June 2004 - 07:10 PM
Posted 08 June 2004 - 08:29 PM
Posted 07 May 2005 - 01:51 PM
Posted 07 May 2005 - 04:46 PM
Posted 08 May 2005 - 08:08 AM
The new pedal sensor was 1576 SEK (approx 120£) excl. the work to have it fitted, which was painful because the third bolt hoiding it is very difficult to reach. Don't know how much the would charge for the work since my car was still under warranty, and therefore they did not specify this.My suspicion was that it was a dodgy pedal sensor, and this thread seems to support that. Any ideas how much Vauxhall will charge in labour to replace it? My car's out of warranty by 2 months
However, swapping it did not help me (not saying that the sensor might not be the problem in your case). I noticed there are some specific error codes for a faulty pedal sensor and I did not have any of them. Also, my guess would be that a "reboot" would not help very much if the sensor was really bad. I posted the DTC:s (Diagnostic Trouble Codes) I found out using Scantool's obd-ii interface & software, don't know if you have any possibily to find out what you have?
Posted 10 May 2005 - 08:22 PM
Edited by slimvince, 10 May 2005 - 08:23 PM.
Guest_AntB (Guest)
Posted 18 May 2005 - 03:07 PM
Posted 19 May 2005 - 01:55 PM
Posted 19 May 2005 - 02:09 PM
Posted 22 May 2005 - 04:43 PM
Posted 22 May 2005 - 05:47 PM
Posted 30 May 2005 - 10:53 AM
Guest_AntB (Guest)
Posted 31 May 2005 - 06:17 AM
Posted 10 June 2005 - 09:04 PM
Mine just did this again, about 1,500 miles since the last time it did it but still irritating. Gives me less confidence in the car to put it in situations where power is required on demand (overtaking, fast cornering).I then cleaned (compressed air and contact spray) the connector at the pedal sensor, the connector on the ECU and a connector where the cable is split behind the coolant bottle holder - and - knock on wood - this far it seems this have cured the problem.
Have not been able to do much driving yet...
While cleaning the connectors I noticed that some of them (but not all) seemed to have some kind of transparent grease on and in them - is this normal? Why then not on all connectors?
Can you take some pictures of the bits you cleaned? I'm guessing it's pretty easy to find the connector for the accelerator pedal, but what about the other connectors?
Do I need to take the dash off to get to the accelerator pedal connector or is it accessible via the footwell?
Posted 10 June 2005 - 09:46 PM
Edited by slimvince, 10 June 2005 - 09:54 PM.
