Engine Warning Light Problem
46 replies to this topic
#41 geoff200
geoff200
  • 77 posts
Posted 27 September 2005 - 01:36 PM
How come the turbo doesn't suffer in the same way? Different connectors? Better wheather proofing?
#42 leeline99
leeline99
  • 157 posts
Posted 01 October 2005 - 01:02 PM
Here is a pic looking from outside the car's left hand side looking inwards through the left rear wheel arch, where the left rear wheel usually sits. You can see the yellow Bilstein damper at the bottom of the pic, and the two connectors in the middle, one blue one black. Just behind the blue connector you can just barely see the cooling fluid bottle.
It is possible to get at bot of the connecters with out taking the wheel and wheel arech liner off.
I just did it.
You need to unclip the expansion tank. One clip. You can leave everything connected , and just move it out of the way (well it gives about an extra inch of space.)
once out of the way. There are two clips which hold the connectors onto the back of the bracket that holds th expansion tank. Squeeze together and push away from the braket.
The bracket can now be removed 2x 14 mm bolts. (no nuts to fall out either)
Ease the bracket down into the engine bay.
You can now get at both the blue and the black connectors.
Refitting
Note: when refitting clip the connecters back onto the expansion tank bracket before re-attaching.
Do up both bolts, Careful not to drop them. I put a bit of loc-tite on mine too.
And then clip the tank back on.
I checked both of mine and they looked very clean.
Will move onto the pedal sensor next.
Funnily enough the light came on 5 days after a service at vauxhall.....
Any thoughts??
Cheers
#43 slimvince
slimvince
  • 649 posts
Posted 14 October 2005 - 06:16 PM
Will try to get a replacement of the connectors at the Opel-shop.
What connectors can be changed?
Male and female at pedal?
Male and female at ECU?
Edit: Had a look at SlimVince's pictures. Is there a conector at the coolant reservoir also?
The loom that goes from the pedal to the ECU is split in two halves, one half going from pedal to the expansion tank, the second half going from the expansion tank to the ECU, - hence an extra connector sitting on the back of the expansion tank connecting the two halves together. I noticed it requires quite some force to make an audible click when connecting again after taking it apart. Since I did this about a month ago the problem has not showed up again (yet?).
In my case both the ECU and the pedal have been replaced meaning that the only remaining parts to replace are the cables. My Speedster has just been garaged awaiting next spring :( , so not until April I'll know if it still is ok.
#44 slimvince
slimvince
  • 649 posts
Posted 30 June 2006 - 03:27 PM
thumbsdown Back again :beat: Read a DTC p1271 using my obdii interface and Scantool software (which by the way now reads and clears the codes correctly). Was fine April, May and most of June. Might have a go at all the connectors again. :angry:
#45 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 14 December 2010 - 01:14 PM
I now have this :angry: I'm not looking forward to the drive home :beat:
#46 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 14 December 2010 - 02:49 PM
This has happened to mine once. When my dad tried to start the car after a spin with the throttle slightly depressed and confused the sensor. Went away after an engine start. I hate electronic throttles thumbsdown
#47 FLD
Posted 15 December 2010 - 02:06 PM
Happened to me. The connectors were clean. What mine was down to was the wiring moving around levering open the contacts. Have a look at the female contact side you might find one or two that are loose / opened up. Close them with a pin or fit a new terminal....or solder up all the wires and do away with the plug!
