Engine Warning Light Problem
#21
Posted 10 June 2005 - 09:52 PM
#22
Posted 10 June 2005 - 10:24 PM
#23
Posted 11 June 2005 - 05:28 PM
#24
Posted 19 July 2005 - 08:34 AM
#25
Posted 19 July 2005 - 08:35 AM
#26
Posted 19 July 2005 - 08:38 AM
#27
Guest_AntB (Guest)
Posted 19 July 2005 - 09:34 AM
#28
Posted 19 July 2005 - 10:30 AM
Opel have not yet come back to me with any idea on what might cause this problem (since May(!))... I thought it might be moisture in the connectors, and everything looked fine for a while until it came back again at three different occasions in July - all at sunny an dry weather (and I keep my car in a dry garage...).you've got rubber boots over yours i haven't!
pull the boots off. push the centre grey tooth of the plastic locking clip then slide out.
so this is the cause of all the failures?! damp?!i'm going to get that vxt rain cover fitted to be on the safe side
cheers slimvince![]()
Tried to push the little clip at the red arrow and then slide it all out in the direction of the green arrow but it is still stuck. Some brute force needed
#29
Guest_AntB (Guest)
Posted 19 July 2005 - 10:41 AM
#30
Posted 19 July 2005 - 11:32 AM
#31
Posted 27 July 2005 - 08:47 PM
Managed to disconnect the ECU; there is an aluminium bar that blocks part of the connector-mechanism to slide out when you lift the lever on the connector and this will have to be removed firstOpel have not yet come back to me with any idea on what might cause this problem (since May(!))... I thought it might be moisture in the connectors, and everything looked fine for a while until it came back again at three different occasions in July - all at sunny an dry weather (and I keep my car in a dry garage...).you've got rubber boots over yours i haven't!
Tried to push the little clip at the red arrow and then slide it all out in the direction of the green arrow but it is still stuck. Some brute force neededmaybe?
In the piccie I posted earlier, the green arrow actually points at one of two bolts that holds the alu-bar in place. Further to the right you can see the other one, this time a torx.
#32
Posted 05 August 2005 - 07:19 AM
#33
Posted 05 August 2005 - 08:53 AM
#34
Posted 08 August 2005 - 09:05 AM
Edited by joneian, 08 August 2005 - 09:07 AM.
#35
Posted 08 August 2005 - 10:49 AM
The same code on mine: P1271 "Accelerator Pedal Position (APP) Sensor 1-2 Correlation" (in Swedish though).Heard about yet another swedish speedster with the same symptom, do not know if it was the exact same error code.
Values on sensor no1 was 1,0 V and sensor no2 was 4,5 V.
I'm booked at the Opel-shop for 22th August.
Tried to get my Opel-shop to talk to yours, but they wouldn't.
Has happend twice for me. On long runs with static pedal work both times.
#36
Posted 11 August 2005 - 01:52 PM
#37
Posted 23 August 2005 - 06:23 AM
Picked the car up this morning. They talked to a technician at headquarters in Stockholm. All they did was some adjustments. And the cost was 350 SEK (25£).I'm booked at the Opel-shop for 22th August.
All I have to do now is drive and see if it helped...
#38
Posted 01 September 2005 - 07:25 AM
#39
Posted 10 September 2005 - 12:58 PM
Cable-side, ECU/Pedal-side or both?Replacing all the connectors (both ends) seems to cure the issue on the cars we've seen
Edit: do you fix this by replacing the loom and/or replacing the connectors that are part of the ECU / Pedal-body? ...and the cable-to-cable connectors at the coolant reservoir?
The service technician still has not got any reply from Opel Germany
Going to recommend replacing the cables and connectors...
Edited by slimvince, 10 September 2005 - 01:53 PM.
#40
Posted 27 September 2005 - 07:25 AM
Well it didn't help. It happend again. Static pedalwork (highwaydriving) again.Picked the car up this morning. They talked to a technician at headquarters in Stockholm. All they did was some adjustments. And the cost was 350 SEK (25£).I'm booked at the Opel-shop for 22th August.
All I have to do now is drive and see if it helped...![]()
Will try to get a replacement of the connectors at the Opel-shop.
What connectors can be changed?
Male and female at pedal?
Male and female at ECU?
Edit: Had a look at SlimVince's pictures. Is there a conector at the coolant reservoir also?
Edited by Nillet, 27 September 2005 - 07:28 AM.
