BTW was the recall on the vxr air-con ever done on yours
Posted 16 June 2011 - 04:25 PM
Posted 16 June 2011 - 04:29 PM
i am thinking that if you wield two Suzuki GSX 1300 R Hayabusa's together and then ride it Ben Hur style you will be approaching where you want to be performance wise (and handling wise)
Posted 16 June 2011 - 04:37 PM
Bunch of tossers
you lot are a right pain in the arseits unreal
Posted 16 June 2011 - 04:42 PM
Bunch of tossers
So we are not a "bunch of tossers" anymore?
Posted 16 June 2011 - 05:23 PM
Posted 16 June 2011 - 07:56 PM
In you're other thread you said i've had a scare or two in the wet
Posted 16 June 2011 - 07:59 PM
I'd at least give yourself a couple of months. Front wheel drive astra to Rwd stage 2 tubby has to be a learning curve for anyone I would think. This isn't meant to be patronising, although it probably is and I understand that your just looking at prices. Maybe I'm getting old...
Posted 16 June 2011 - 08:01 PM
Maybe you're just being sensible.
Posted 16 June 2011 - 08:50 PM
Posted 16 June 2011 - 09:21 PM
Posted 16 June 2011 - 10:13 PM
Posted 16 June 2011 - 10:19 PM
Are you after mid range grunt or liner power delivery that makes you want to chase the red line?
Posted 20 June 2011 - 10:14 AM
only seen this late mate.....soz would of met up.....I'm down in Neath tomorrow.
You around?
Posted 20 June 2011 - 04:14 PM
If you dont like a guys questions you can always click and move on.Why give a lecture just because its not your cup of tea ?
Bloody hell i was just wondering. God you lot are a right pain in the arse its unreal. I asked a question doesnt mean im going to do it NOW, i dont have the money at the minute anyway. Obviously im going to look at getting the car sorted first and then a good set of tyres, getting used to the car and so on but this is a forum... didnt think there was any harm in asking that
You come accross as being totally obsessed with BHP and "smoking others" (whatever that means,i assume some sort of illegal substance)
If you don't like being patronised grow up! Then you will find this a welcoming, friendly and informative place
Posted 20 June 2011 - 08:07 PM
Posted 20 June 2011 - 09:01 PM
Ah yeah forgot you're on the stage 2 map still. Grey area as you say. It's stage 3 hardware with a scaled-back map so it's stage errrr...Spuk, have I actually got stage 3???? I have stage 3 power by Courtenays standards. But I'm running the MMG stage 2 map with an uprated intercooler. Stage 3 is a bit of a grey area, and not many go there. They normally go to stage 4. However, the difference in cost between a stage 2 and stage 4 is quite a lot because of the extra hardware. To eek anymore power out of mine, I would really need the clutch changing, or run the risk of screwing up the standard clutch. I'm already well over it's 'rated' spec anyway.
Posted 20 June 2011 - 09:03 PM
Posted 20 June 2011 - 09:19 PM
As slindborg says (but a little more scaled down
Spuk, have I actually got stage 3???? I have stage 3 power by Courtenays standards. But I'm running the MMG stage 2 map with an uprated intercooler. Stage 3 is a bit of a grey area, and not many go there. They normally go to stage 4. However, the difference in cost between a stage 2 and stage 4 is quite a lot because of the extra hardware. To eek anymore power out of mine, I would really need the clutch changing, or run the risk of screwing up the standard clutch. I'm already well over it's 'rated' spec anyway.. I presume you're holding back the map for the clutch's sake then? I would've thought you can probably squeeze more top end power but leave the low end torque the same, that shouldn't negatively affect the clutch then should it?
Posted 20 June 2011 - 09:42 PM
) stage tuning is a bit grey. In one sense I could argue I have stage 3, as I have stage 3 power, i.e. about 260 bhp. But the other argument is that I don't have all stage 3 hardware / software. I wouldn't call my map scaled back as such. It's a map that is designed to suit the hardware.
Both my torque and power are well over the standard clutch rating. So I'm already on thin ice. And to be honest, I am really happy with the car and the way it performs. The new intercooler has helped it's responsiveness. And I know its given me a few bhp extra (but I don't know how many extra though)
Posted 21 June 2011 - 06:23 AM
