Battery Keeps Going Flat
#41
Posted 26 July 2011 - 07:48 PM
#42
Posted 26 July 2011 - 08:05 PM
#43
Posted 26 July 2011 - 08:10 PM
Can you turn the stereo on when the ignition is off?The purple and the red ?
These are the switch and permanent live I think ,
These are ok the cd dosnt spin constantly just when I first power it up
I guess the other plug is speakers ? Makes no difference if this is in or out
But remove the mains plug and no drain
Also when I put the fuse in it sparks a little so this would confirm a drain or power usage
#44
Posted 26 July 2011 - 08:15 PM
#45
Posted 26 July 2011 - 08:21 PM
SOunds like the permanent live and switched live are the right way round.No it goes off with the ignition but retains it's Chanel settings
As it is standard ISO wiring, have you got another stereo you can chuck in?
#46
#47
Posted 26 July 2011 - 08:25 PM
#48
Posted 26 July 2011 - 08:27 PM
Tried 2 Sony head units and get the same results
Ok, do you have a non Sony head unit you can try?
As I mentioned before the main wires that should be connected are two lives, one ground and 4 speaker wires. What wires are connected on yours?
#49
Posted 26 July 2011 - 08:52 PM
#50
Posted 27 July 2011 - 06:46 AM
The other 8 are for a 4 speaker system. Assuming you only have the two speakers only 4 should be connected.2 lives 1 permanent and 1 switched 1 earth
Then the other plug has around 8 but having thus plugged in or not makes no difference
It sounds like the power wiring is right as the unit is turning off when the ignition is turned off. However there is a chance that the stereo may still switch off when the ignition is turned off even if the permanent and switched lives are swapped. Can you turn the stereo on after it has gone off when the ignition has been turned off?
#51
Posted 27 July 2011 - 08:41 AM
#52
Posted 27 July 2011 - 09:37 AM
#53
Posted 27 July 2011 - 11:12 AM
#54
Posted 27 July 2011 - 11:28 AM
Think that's a good plan I will remove the fuse while its in the garage for a couple of weeks and see what happens when I push the starter then if it's bot flat it must be something on that circuit
How would it be if a ran a new earth and perm live to the radio and did away with the existing ?
Do you program the buttons on it? if not then just remove the permanent power and keep the ignition one. Then it will just reset your head unit every time but will not draw any power when the ignition is off!
#55
Posted 27 July 2011 - 11:39 AM
#56
Posted 27 July 2011 - 11:49 AM
Before you change the wiring you want to establish that it is the stereo / wiring that is the issue. Charge the battery, pull the fuse and see what happens.Think that's a good plan I will remove the fuse while its in the garage for a couple of weeks and see what happens when I push the starter then if it's bot flat it must be something on that circuit
#57
Posted 27 July 2011 - 11:50 AM
#58
Posted 27 July 2011 - 11:51 AM
Whilst trickle chargers are handy, I wouldn't rely on that. All that is going to do is mask the problem. I would want to understand what the issue is and rectify it. The use the trickle charger if you want.
Of course you're spot on, but this electrical problem has been playing for about 10 years now, and the amount of bleeding nuckels and battery investments (some people up to 3 or 4 a year) i have seen passing by on .org makes the money for a trickle charger well spent
Hail to the king for whever fixes this permanently though
Edited by smiley, 27 July 2011 - 11:53 AM.
#59
Posted 27 July 2011 - 12:27 PM
I sincerely doubt there is a one fix fixes all solution to this. Electrics run throughout the car and I suspect will differ considerably.
Unfortunately it is a time consuming process that needs to follow a logical process to deduce where the power drain is.
#60
Posted 27 July 2011 - 01:42 PM
