Battery Keeps Going Flat
#61
Posted 27 July 2011 - 01:43 PM
#62
Posted 27 July 2011 - 04:43 PM
#63
Posted 27 July 2011 - 08:59 PM
#64
Posted 28 July 2011 - 05:20 PM
Edited by christhegasman, 28 July 2011 - 05:21 PM.
#65
Posted 28 July 2011 - 08:43 PM
#66
Posted 28 July 2011 - 08:50 PM
#67
Posted 28 July 2011 - 09:01 PM
As said in a previous post, there is a chance that the Sony head unit has permanent live and switched live opposite. Should be simple enough to try by swapping the wires over.Might be ok now
I have plugged in a crap goodmans unit and it seems ok
But can't believe 2 Sony headsets gave the same problem unless I have a wire problem that has vanished with moving the cables around
Can't explain it but if it stays ok I will leave well alone
Also thinking if I gi on my hols for a couple of weeks it will possibly still go flat so considering leaving my solar charger on just wondered if it would be ok for 2 to 3 weeks
Thanks for all the advice guys but it may always remain a mystery
For me I'd fully charge the battery, put the goodmans head unit in and leave it whilst away. If you come back and all is well its either a faulty head unit or you need to look at the wiring. BTW no solar charger whilst you are away. If you do that then you'll not know if you've got to the bottom of the problem.
#68
Posted 28 July 2011 - 09:07 PM
I'm trying to think back to what I originally stuck in the car to replace the VDO Dayton and think that might have been a Sony and that was when I encountered the reversed connections on the ISO connector. Definitely worth checking the Sony wiring diagram to see which lead on it's loom it's expecting a permanent live on and which it's expecting a switched live on. Then comparing that to the main power ISO connector on the cars loom to check they are in the corresponding place.
#69
Posted 28 July 2011 - 09:51 PM
Is it ok to leave these on permanent if the cars not being used for a few weeks or more
The speedster guy has it plugged in for weeks, as he hardly drives it.
#70
Posted 29 July 2011 - 09:47 AM
