Mot isn't a problem especially for Jjj race car etc
How big we talking?
What do you think should be done to reduce front drag?
As far as I can see the canards creat down force in 2 different wat ways:
1. the curvature generate downforce in a similar way to a rear wing in the air flow going around the nose of the car and down the sides but as the front of a vx is square it would be dificult to achive this without having them stick out of the sides of the car, which I suspect is probably against reg. as well as MOT.
2. as they stick out infront of the car they act like mini spliters and create areas of high prssure above them to push down on them but this also increases drag.
Additionally the ones on the elise above are angeled so that they take the airflow up over the wheel arches so that it should reduce the drag they cause.
As for reduceing drag in the paper I read on the ECO-Speedster aerodynamics one of the main areas of improvment was to extend the nose to get rid of the blunt front end. I suspect that as with the canards this would be against as most regs require you to keep the production siloette. However you could cut the flat bits out then then channel the flow round the side of the car.
