Help! Locked Out With Flat Battery!
27 replies to this topic
#21 Macanear
Macanear
  • 5 posts
Posted 16 March 2012 - 10:12 PM
sent direct PM also thanks.......car has been lying under cover over winter...appreciate any help on this ....and I understand the concern that the request is genuine.Macanear
#22 lilpidge
lilpidge
  • 28 posts
Posted 17 March 2012 - 03:16 PM
Hi All, I did promise to update this thread once I'd replaced my backup battery. Sorry it's taken so long - and thanks Macanear for prompting me! I've done the work - and as I don't use the car as often as I'd like, the main battery has gone flat a couple of times since my panic above, but fortunately the backup battery is now doing it's job and I can get inside to pop the bonnet and get the car on charge. In answer to questions above...Yes, the backup battery is charged by the alternator when the engine is running - and also it seems when the engine isn't running! Therefore, if you have a crap backup battery that isn't holding its charge, your main battery will continue trying to charge it - and therefore flatten itself! (This may only happen whilst the main battery is freshly charged - after a run for example - and once it drops its' first volt or two, it may stop trying to charge the backup battery. I didn't do extensive testing on this). There are diodes in place (or similar) to prevent the backup battery trying to back feed the main battery and car circuitry. However, if the backup battery is old, it will lose its charge over time and go flat. If it's really old, it will do this quite quickly! Hope this helps!
#23 DJ_SL
DJ_SL
  • 425 posts
Posted 01 December 2013 - 01:45 PM
Hi, have the same problem. Main and backup battery completely dead. Lock nut under bonnet. What's the easiest way to get in? Can somebody please PM me instructions. Thanks in advance.
#24 Bumblebee
Bumblebee
  • 7,592 posts
Posted 01 December 2013 - 01:49 PM
Pm sent
Edited by Bumblebee, 01 December 2013 - 01:57 PM.
#25 chappers2000
chappers2000
  • 489 posts
  • Interests:Sports cars; kit cars, mountain biking
Posted 01 December 2013 - 05:52 PM
Ah - the joys of the NA....no central locking! http://www.vx220.org...supgraemlin.gif
Easy to fit if you really want it, as I did. Since mine' s now an NA with remote central locking, I fitted a waterproof socket under the front clam behind my turbo splitter, as I don't have the back-up battery. Now if the main battery is flat I can connect up a charger without opening the bonnet, or just connect a solar charger/battery conditioner. Just need to make sure I disconnect it before reversing out the drive.
#26 Gareth Jones
Gareth Jones
  • 66 posts
Posted 02 December 2013 - 09:19 PM
take the drivers side arch out 4 screws I thick. I had to take the N/S out to get my locking wheel nut. you can get to the nut with the wheel on. I found the drivers side easier to pull the bonnet catch wire. once the bonnet open put power to the battery and open the door. all done
Edited by Gareth Jones, 02 December 2013 - 09:21 PM.
#27 ratboiler
ratboiler
  • 1,340 posts
Posted 03 December 2013 - 07:40 AM
So where is the back up battery located in the boot, and where do you get a new one from, lastly is it easy to fit.
Pictures would be a help.
Thanks
#28 techieboy
Posted 03 December 2013 - 08:32 AM
http://www.vx220.org...backup-battery/
