Vx Turbo Still Won't Start Has Fuel Compression And Spark.
Posted 24 October 2011 - 06:35 PM
Posted 24 October 2011 - 06:55 PM
Posted 24 October 2011 - 07:00 PM
Don't think it could be as it has a new full 3" 2ubular on it that has only done about 300 miles unless the cat has failed or maybe the turbo.More things to check at the weekend.blocked exhaust
Posted 24 October 2011 - 07:06 PM
Posted 24 October 2011 - 07:15 PM
Thanks for that I will try that on Saturday though I hope it isn't the cat as it shouldn't of failed in under 300 miles.loosen a flange before the cat and try starting it, if the cat has melted then it will stop the engine running
Posted 24 October 2011 - 07:38 PM
Posted 24 October 2011 - 07:42 PM
Posted 24 October 2011 - 09:54 PM
Posted 25 October 2011 - 07:18 AM
Posted 25 October 2011 - 04:39 PM
Posted 25 October 2011 - 06:26 PM
Posted 25 October 2011 - 08:31 PM
Posted 29 October 2011 - 12:56 PM
Posted 06 November 2011 - 06:09 PM
Posted 06 November 2011 - 06:46 PM
I'm probably not going to be able to offer much more help than what's been suggested already, but have you checked the immobiliser and the earthing points?
Posted 06 November 2011 - 06:57 PM
Thanks for the input.I have checked all the wiring several times and as there is fuel and spark it shouldn't be an immobiliser issue.Also with the crank sensor worn down there must be something seriously wrong inside the engine as the sensor should not be touching anything.Sorry to hear about your troubles
try not to get disheartened.
Posted 06 November 2011 - 08:02 PM
Posted 07 November 2011 - 07:06 PM
Posted 07 November 2011 - 07:26 PM
Posted 07 November 2011 - 07:34 PM
Is examination of the bottom end shizzle possible by removing the sump and the balancer shafts? Sorry I am getting out of my depth now. Bring on somebody who's stripped an engine before and could maybe advise what could have eaten the crank sensor. Maybe post a picture of the damage to the sensor?Thanks Ormes.The crank sensor hadn't been removed before as far as I'm aware.
After a long think about what to do next I have decided that one way or another I am going to get my VX fixed as I have worked out that with the knackered engine even if I completely striped the car and sold it as parts I would probably not even get back what I have spent on it since I bought it.
Before I start looking a what other equipment and tools I will need to get for removing the engine is there anybody near Lichfield Staffordshire that has good knowledge of these cars and engines that would be able to spare some time and have a look at the car with me on Saturday just to make sure before I start taking it apart that the engine is definitely the problem obviously there will be some beer money in it for them
