Kumho (Ecsta Xs) Ku36
48 replies to this topic
#1 aKra
aKra
  • 109 posts
Posted 02 November 2011 - 05:55 PM
With my new TD1.2's coming in from the groupbuy i'm trying to decide which tires i will fit on them... Posted Image (like most of us)
But the question is can i fit 215/45/R16 on the fronts without any problems? Will only have a 3.9% radius difference (too fast) and the mostly fitted 205/45/R16 will have a whopping 5.3%!
I've looked at the Yokohama AD08 but if they reach -10C even in storage they will be brittle and take damage Posted Image! (according to Yokohama NL)
Kumho ECSTA XS KU36:
#2 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 02 November 2011 - 06:04 PM
Can't help with the size query Im afraid but I do like the look of the KU36s. As far as I know you'll be the first to try them on a VX on the forum thumbsup
#3 Bumblebee
Bumblebee
  • 7,592 posts
Posted 28 April 2013 - 01:38 PM
Any more takers on this thread? Would be nice to know :)
Edited by Bumblebee, 28 April 2013 - 01:39 PM.
#4 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 28 April 2013 - 01:55 PM
From memory I don't think you can get the correct sized fronts. Haven't read any rave reviews about them either. If you want a budget option then probably best to stick withe federals. Or if you don't mind spending more R1Rs
#5 Bumblebee
Bumblebee
  • 7,592 posts
Posted 28 April 2013 - 05:43 PM
Think il go for either ku36 in a 215 45 16 or ad08's in 215 45 16
#6 2-20
2-20
  • 1,317 posts
Posted 28 April 2013 - 08:54 PM
I've them also
but in 215/45/17 front
245/40/17 rear
#7 Bumblebee
Bumblebee
  • 7,592 posts
Posted 28 April 2013 - 08:59 PM
I've them also
245/40/17 rear
How do you find them? What previous tyres can you compare them too? I'm currently on khumo ku39's but I fancy going for 215 45 16. I presume you don't get any rubbing?
#8 Lou_m
Lou_m
    Addicted to Hooning
  • 1,904 posts
  • Interests:Cars, motorsport, cycling
Posted 28 April 2013 - 09:03 PM
205 45 16 is the std size that most go for on the AD08's. I've had them for 2 years now. Currently borrowed a set of Toyo T1R's and I really like them for road use. The sidewalls on the AD08's are so stiff they really do muck up the ride quality and I have not noticed a lack of grip with the Toyos at road speeds.
#9 slindborg
Posted 28 April 2013 - 09:06 PM
I had 205/50/16's on my TD's I know many folks ran 205/45/16's and had less scrubbage issues etc.
#10 Bumblebee
Bumblebee
  • 7,592 posts
Posted 28 April 2013 - 09:12 PM
I know the 215 45 16 isn't the norm but there close to 195 50 16 http://www.etyres.co...-calculator.htm
Edited by Bumblebee, 28 April 2013 - 09:16 PM.
#11 Lou_m
Lou_m
    Addicted to Hooning
  • 1,904 posts
Posted 28 April 2013 - 09:15 PM
I know the 215 45 16 isn't the norm but the radius is close to 195 50 16
True, heavier steering though.
#12 techieboy
Posted 28 April 2013 - 09:16 PM
They're not available in 205's on a 16" wheel anyway (assuming you can find anywhere in the UK that actually sells them at all).
#13 2-20
2-20
  • 1,317 posts
Posted 29 April 2013 - 10:09 AM
I've them also
245/40/17 rear
Well, i've only done a few hundreds kilometers and on the road only so i cannot compare the grip.
They are installed on 8 x 17 OZ ultraleggera wheels ET 35 at the rear and ET 20 (15 mm spacer) at the front.
At the rear i've not increased the mass at 19.3 kg per wheel , the tyre itself is 11 kg . This is slightly lighter than a Superleggera and R888 225/45/17 combo.
No rubbing at the rear
At the front the tyre is 9.2 kg and when installed on its wheel the weight is 17.6 kg. It's 2kg more than with my 16" wheel but it's the price to pay to be road legal (in France)
The tyre rub on the clam at full lock at the classical location with this tyre size . However, i may not need extenders as 1 or 2 mm of clam wear could be sufficient.
So far the feeling is OK . They are quiet despite the thread pattern.
I still have to lower the car a bit more notably at the front and a new geo setting is necessary to really investigate their capabilities.
#14 Bumblebee
Bumblebee
  • 7,592 posts
Posted 29 April 2013 - 05:00 PM
My cars fitted with speedline's ( front is 7j/16" et 26) which are currently fitted with 205/45/16 ku39's, I put the steering on full lock and there seems to be loads of clearance, more than enough for the extra 5mm for the ku36 215/45/16?
#15 slindborg
Posted 29 April 2013 - 06:19 PM
Get the at moving and going over bumps etc and expect that clearence to bugger off.
#16 Bumblebee
Bumblebee
  • 7,592 posts
Posted 29 April 2013 - 06:22 PM
#17 slindborg
Posted 29 April 2013 - 06:24 PM
Never mind, just fit the widest tyres you can find. Note tyre sizes can lie, eg one models 205 could be as wide as a 215 etc.
#18 anz3001
anz3001
  • 1,617 posts
Posted 29 April 2013 - 08:18 PM
Whilst it is true to an extent most manufacturers produce to ETRTO specs so there shouldnt be too much variance
#19 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 29 April 2013 - 09:04 PM
Awaits techie (or was it JG) posting photo of different tyres stacked next to each other
#20 techieboy
Posted 29 April 2013 - 09:07 PM
Happy to oblige. :lol:
Not all things are equal, even with the same manufacturer (Toyo in this case). :wacko:
