Kumho (Ecsta Xs) Ku36
48 replies to this topic
#41 siztenboots
Posted 30 April 2013 - 12:19 PM
a 235 should fit on those okay , mines a 9J with 235/40/17 . Tyre sizes are not that accurate and vary a lot in the one size.
#42 Bumblebee
Bumblebee
  • 7,592 posts
Posted 30 April 2013 - 12:26 PM
Thanks for that. If they do fit ok (I'm 99% certain they will) can you see any negatives fitting 235/45/17 on the back compared to 225/45/17?
#43 siztenboots
Posted 30 April 2013 - 12:28 PM
I've never tried them , try and compare the rolling radius between them both as this will make the speedo less accurate
#44 Bumblebee
Bumblebee
  • 7,592 posts
Posted 30 April 2013 - 12:36 PM
The speedo doesn't put it out by much ( -1.4%) I.e at 30mph my speedo will read 29,58 mph and at 60mph my speedo will read 59.16mph. I think on standard Vxt wheels the sidewall is slightly bigger at the back compared to the front tyres, so I'm guessing the slightly bigger sidewall on the 23/45/17 won't make much of a difference?
#45 Rosssco
Rosssco
  • 4,185 posts
Posted 30 April 2013 - 12:38 PM
235/45/17 is fine (assuming the ride height and wheel offset isn't too low / high). The larger tyre circumference will effectively serve to reduce the cars final drive, but that shouldn't really have too much of a noticable effect on acceleration if your car has +300lb/ft...
Edited by Rosssco, 30 April 2013 - 12:39 PM.
#46 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 30 April 2013 - 03:51 PM
I tried these out. They are as sensitive to temperatures as a clitorus
#47 techieboy
Posted 30 April 2013 - 03:54 PM
At least spell the bloody words correctly, if you're going to carry on with this stupid fcuking game.
#48 Bumblebee
Bumblebee
  • 7,592 posts
Posted 30 April 2013 - 03:56 PM
If "its a stupid game" don't comment, simples :)
#49 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 01 May 2013 - 08:33 AM
iCrap.... Apologies.
Clitoris
