A Z20Let Is Reborn (Pic Heavy)
115 replies to this topic
#61 luke.
luke.
  • 2,167 posts
Posted 17 January 2012 - 10:59 AM
jsut seen another come on ebay overnight , its in Luton if anyone has a van?
http://www.ebay.co.u...=item1c22eea36d
I have a combo van if that helps. Am based in midlands. Don't mind driving if you cover diesel
Drop me a text on 07983364489 if you are interested
Edited by luke., 17 January 2012 - 11:04 AM.
#62 siztenboots
Posted 17 January 2012 - 11:04 AM
yes i'd cover expenses of course . just need to do some background checks on the seller.
#63 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 17 January 2012 - 11:11 AM
I was under the impression that the LEH block wasn't as strong as a LET with the cylinder walls being thinner, am I mistaken? I know this was the diagnosed problem that caused danger7's engine failure :unsure:
#64 siztenboots
Posted 17 January 2012 - 11:12 AM
well, they look a legit business , I would hate to send in some poor bugger to collect from a pikey site lol
facebook: http://www.facebook....100002468770635
http://www.quattroco.../main/index.php
Quattro Coachworks,
H14 ,Park Avenue Estate,
Sundon Park Road,
Luton
Bedfordshire LU3 3BP
#65 siztenboots
Posted 17 January 2012 - 11:14 AM
randy's engine seems okay sofar . tbh until we stage 5 it, it should not be a problem.
#66 steveboyslim
steveboyslim
  • 120 posts
Posted 17 January 2012 - 03:25 PM
Hmmm, it's hard to know if that is justified. Maybe.
The main reason the Z20LEH had piston jets installed was for emissions reasons (particularily at idle) apparently, not specifically for cooling at high revs.
That is not correct, they were/are installed for under piston cooling.
I would also wedge the waterway.
Steve
As I understand it the stock VXR had to run very lean (and hot) to hit emissions targets, so the under piston squirters were used to keep temps in check. I ran my car for 3 years without them with no detrimental effects although I am now using them. We have found these engines are quite knock limited so anything you can do to keep the combustions temps down is a good thing. Its one thing making the numbers on the dyno, quite another to keep hold of them when the car is heat soaked on the race track. Remember though, if you do use the oil squirters the cool the pistons you then need enough oil cooling capacity to shed that heat into the atmosphere...
Just about all engine manufactures use oil jet cooling for reliability on turbo engines, diesel or petrol.
Oil cooling does not apear to be a problem using the watercooled set up although with a thicker core water radiator with road use.
I have seen the water cooling replace with an air cooled cooler.
I have used a supplementary air cooled cooler, fitted in the supply feed to a lamova type water cooled cooler, replacing the standard water to oil cooler.
Steve
For the road the little laminova is fine... For track worth it can't even start to keep things in check on high powered cars. I tend to use the oil laminova for the gearbox and a big air/oil cooler up front although on my car there isn't the room up front so I have twin massive Setrabs at the back with a 13" high capacity puller fan which just about gets the coolers into a sensible efficiency range. Keeping things cool in high powered little plastic mid engined cars ain't easy...
laminova was used in series with air cooled rads.
steve
#67 steveboyslim
steveboyslim
  • 120 posts
Posted 17 January 2012 - 03:27 PM
he's being a bit keen on price , I wonder if he would take £1500 cash in person, rather than auction.
I think I can sort you one out for that money.
I will confirm wednesday.
Steve
#68 siztenboots
Posted 18 January 2012 - 12:05 PM
Steve
Okay, bear in mind that a lot of the parts , turbo, clutch, flywheel, alternator, starter, aircon pump, intake manifold, throttle body won't be required. what is of value is the provenance of the engine.
It would be useful to swap contact information as I am sure we'll need a whole load of bits, and I understand you keep a lot of this on the shelf.
mob: 07564 124266
Steve
#69 steveboyslim
steveboyslim
  • 120 posts
Posted 19 January 2012 - 10:55 AM
Steve
mob: 07564 124266
Steve
The engine is from a reputable salvage yard I deal with which offer a warranty, apart from that I do not have any other details, it was fully dressed with all the parts you don't want, but is only available compllete.
Too expensive for me to purchase for stock, if it is still available I will find out more details.
Message sent with my phone number.
Steve
#70 siztenboots
Posted 17 June 2012 - 10:28 AM
better to update this project thread
removing some tough exhaust studs
all done, head is ready
#71 siztenboots
Posted 17 June 2012 - 02:55 PM
just a coarse first pass on three so far, getting familiar with the casting high points
#72 Winstar
Winstar
  • 4,264 posts
Posted 23 June 2012 - 10:51 AM
Steve
Steve
Yes and the reason they need to fit them is because of the Emissions and CO2 targets increasing combustion temperatures
I worked on the LET to LEH upgrade, and as Chris said, they where only fitted as the engine wouldn't meet the durability targets with the std LET bottom end
Edited by Winstar, 23 June 2012 - 10:51 AM.
#73 siztenboots
Posted 23 June 2012 - 10:57 AM
so I don't need to bother and can keep the LET block as std, but still run the VXR pistons and some steel rods. is there any optimum temperature for the cylinder head?
#74 Nev
Posted 23 June 2012 - 11:49 AM
As low as sensibly possible I would imagine.
#75 steveboyslim
steveboyslim
  • 120 posts
Posted 24 June 2012 - 07:24 AM
Steve
Steve
Is durability not similar to reliability ?
Oil jetting have several benifits and for the £250 is cost to supply and fit the BMW jets I use, in my opinion a very worth while modification.
With the standard head suffering badly even in standard form with cracks between the exhaust valve seats and the spark plug hole, any additional method of cooling the combustion chamber is worth doing, even more so with 'go faster' chip conversions where the fuelling is often not correct, even when the standard ecu is re- mapped.
Steve
Edited by steveboyslim, 24 June 2012 - 07:29 AM.
#76 siztenboots
Posted 25 June 2012 - 11:26 AM
next thing on list , new piston rings for the vxr pistons.
#77 siztenboots
Posted 29 June 2012 - 11:25 AM
rods ordered this week , still plenty on the list to sort out having trouble find a gasket, its between the cylinder head and the alloy block that houses the water temp sensor and the water pipe connector, for a non EGR block looking unlikely to make it now for Le Mans
#78 Nev
Posted 30 June 2012 - 07:59 AM
What gasket are you missing exactly steve? I have a pack of gaskets in my garage, I can look if you tell me.
#79 siztenboots
Posted 30 June 2012 - 09:24 AM
this one, don't see it mentioned on the usual gasket kit
#80 siztenboots
Posted 30 June 2012 - 11:59 AM
cleaning up the forged pistons , just a few minutes in the parts washer , all done by hand this morning , three more to go
