Quick Shift
48 replies to this topic
#21 harboged
harboged
  • 392 posts
Posted 16 November 2015 - 02:54 PM
I'm simply considering modifying the original part as in the attached picture. Cut it in two, remove some material in order to get the same ratio as the short shifter and then weld it together.
Are there any other benefits of buying a short shifter instead of modifying the original one for free?
Edited by harboged, 16 November 2015 - 03:01 PM.
#22 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 16 November 2015 - 04:17 PM
There's one a short shifter of some sort on eBay at the minute. eBay no. 321803752849
#23 stu8v
stu8v
  • 745 posts
Posted 16 November 2015 - 06:05 PM
No real point in fitting one IMHO.
#24 The Batman
Posted 16 November 2015 - 06:11 PM
I loved having this mod on the f23 Hope the pin holding the original one on is ok though as that can Be a pig!
#25 harboged
harboged
  • 392 posts
Posted 16 November 2015 - 08:38 PM
I have had that one as an option (and the other one available for the f23 box) but I don't really like spending that kind of money on something that I'm not sure will make a noticeable difference. Especially when it can be done for free ;) The one you recommend has a nylon bushing as well, which might be good! It's possible to buy it separately though.
Edited by harboged, 16 November 2015 - 08:39 PM.
#26 harboged
harboged
  • 392 posts
Posted 16 November 2015 - 08:39 PM
I hope so too!! :)
#27 Rosssco
Rosssco
  • 4,185 posts
Posted 17 November 2015 - 11:37 AM
I hope so too!! :)
I wouldn't do it to my current car - my last VX had it, and yes it shorted the shift, but it made it relatively stiff to change, and you had to be more accurate in gear selection..
#28 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 17 November 2015 - 02:09 PM
Huge want http://www.gema-moto...ltung-Cabl.html
#29 harboged
harboged
  • 392 posts
Posted 17 November 2015 - 02:17 PM
Has anyone installed this nylon bushing from MTech and if so, was there any significant difference in feel?
Here's a comparison of the original bushing and the upgraded one:
Original:
MTech:
#30 Mattyboi
Mattyboi
  • 482 posts
Posted 23 November 2015 - 01:55 PM
What kit does this elise have to raise the gear stick? ----->
https://www.youtube....h?v=oYdyoePZxvc
From this guys history he wont have spent much on it so it could be shonky but it looks good so worth asking!
#31 the outsider
the outsider
  • 297 posts
Posted 23 November 2015 - 05:31 PM
oh dear!!!!!   What kit does this elise have to raise the gear stick? ----->     From this guys history he wont have spent much on it so it could be shonky but it looks good so worth asking!
#32 harboged
harboged
  • 392 posts
Posted 01 February 2016 - 10:00 PM
harboged engineering got inspired by the £100 mtech shortshifter and came up with this beauty :) It has a replaceable counterweight which makes it possible to optimise the feeling.
Adjustable lever ratio would also be nice to have.
#33 OneYet
OneYet
  • 1,355 posts
Posted 02 February 2016 - 11:23 AM
Nice!
Looks like something from the Batmobile!  :D
Feelreport are now expected.
#34 siztenboots
Posted 02 February 2016 - 12:10 PM
I will upgrade to the mtech nylon bushing as its noticeable when they wear
#35 Paulus H
Paulus H
  • 2,063 posts
Posted 03 February 2016 - 03:56 PM
Nice work harboged
I actually use a slightly longer gear lever, what I was attempting to achieve was avoiding getting 5th gear when I was changing up from 2nd. In simple words, same movement back and forward but better definition accross the gate
Kindly, Paul
#36 don.hasi
don.hasi
  • 320 posts
Posted 05 June 2016 - 10:38 AM
@Paul: where did you get your extended gear lever from? I know, i have found something like this, but i couldnt find it anymore...
#37 MAXR
MAXR
  • 2,719 posts
Posted 06 June 2016 - 05:13 PM
I often have gear selection issues when really hot. I was also considering a short shifter. Do you think the mtech short shifter & nylon bush would improve gear precision? I don't mind precise but notchy.
4th to 3rd is a pain, It often goes into 5th instead. I think a big problem for me is that I have removed my boot floor & I think the heat from my exhaust silencers are contributing greatly to my gear selection issues.
The mtech quick shift youtube video with the nylon bush looks impressive.
#38 Nev
Posted 06 June 2016 - 09:00 PM
Hi Max, if you remember your gear shift is poor due to one of your adjustment lock nuts being completely lose at the turret end, such that the adjustment threaded bar was able to unwind itself. Also, the C-cups on the ends of the cables that fix to the turret are substandard or worn and probably contribute to more play. Getting rid of those tie wraps with a proper solution (maybe rose joints?) and maybe a heat shield would help solve this for you, I am sure.
Lastly, if you look at the routing of the cables to the gearbox, it might be possible to twist them and offer them up to the gearbox in a better "line" such that there is less twisting. I had a problem like yours once briefly and I simply solved it by adjusting where the cables ran slightly.
GL.
Edited by Nev, 06 June 2016 - 09:03 PM.
#39 MAXR
MAXR
  • 2,719 posts
Posted 07 June 2016 - 06:12 AM
GL.
Nev,
I've always had gear selection problems for the past two years at least, way before the new cables were fitted. There seems to be a lot of slack in the linkages on the box which isn't helping, as in the mtech video.
#40 harboged
harboged
  • 392 posts
Posted 08 June 2016 - 10:29 PM
On my car with 32,500 miles on the clock the nylon bush had more or less no play at all, so I didn't bother about it. I'm pleased with the feeling of my short shifter :)
