Possible Piston Ring Issues?
Posted 22 March 2012 - 06:28 PM
Posted 22 March 2012 - 06:41 PM
Posted 22 March 2012 - 06:45 PM
Posted 22 March 2012 - 07:02 PM
Posted 22 March 2012 - 07:43 PM
Posted 22 March 2012 - 09:02 PM
Posted 22 March 2012 - 09:11 PM
Leak down test
How hard/long does that take?
In others words - will I have the effort required to go out and do it?
Posted 22 March 2012 - 09:17 PM
Posted 22 March 2012 - 09:25 PM
Posted 22 March 2012 - 10:15 PM
Can you get hold of a compression tester ?
Takes a few mins and you can muster up the effort for this
Posted 22 March 2012 - 10:32 PM
Posted 22 March 2012 - 10:37 PM
Wait. Were the bits on intake side of the engine? If so, they are unlikey to originate from within the engine....
That's what I thought, but it seems odd they were piston ring shaped.
Posted 22 March 2012 - 10:39 PM
Posted 22 March 2012 - 10:41 PM
Posted 01 April 2012 - 12:40 PM
Posted 01 April 2012 - 03:16 PM
Posted 01 April 2012 - 03:45 PM
Posted 01 April 2012 - 05:49 PM
if you loosen the oil cap it should just sit there in the cam cover, there should also be a small resistance to lift it up, usually it can be pulled back down by the engine
When the engine isn't ticking over I can remove the cap no problem, sometimes gets a bit stuck but I thought that was just due to the fact I hardly ever open it up.
Am checking the oil levels tomorrow I think to see exactly what it's drunk in 1k miles.
When I got my intake mani for my SC con from the US. I found bits of metal in it that had found there way out from the engine when the car it came off engine blew.
Seb had you got the breather connected to the intake in that Vid?
Breather on the cam cover is just venting to a little filter sat inside the engine bay.
Posted 01 April 2012 - 06:43 PM
if you loosen the oil cap with the engine running it should just sit there in the cam cover, there should also be a small resistance to lift it up, usually it can be pulled back down by the engine breather system
Edited by vocky, 01 April 2012 - 06:44 PM.
