2,2 Sc Dies Above 4000 Rpm
51 replies to this topic
#1 OneYet
OneYet
  • 1,354 posts
Posted 25 April 2012 - 07:37 PM
I have been enjoying my stage II SC for about a month now. It has been fun. But on the way home from work today she died. I tried to restart her and and after a couple of tries she lives. Engine light is on though. And she revs between 1000 and 2000 rpm up and down and she does not react to the throttle at all. Then she dies again, starts and dies. After a few minutes of this I can get her going so much so she is driveble a mile or so before she dies again and if I rev her more than 4000 rpm she dies straight away. Well not really dies but the throttle dies and she idles between 1000 and 2000 rpm: again. Does this make any sense to you? Any ideas of what to do?
#2 vocky
Posted 25 April 2012 - 07:42 PM
map sensor or loom plugs (aka plugs of doom)
#3 Ormes
Ormes
  • 4,612 posts
Posted 25 April 2012 - 07:53 PM
Crank sensor?
#4 OneYet
OneYet
  • 1,354 posts
Posted 25 April 2012 - 07:57 PM
I ran down to my garage at once. The MAP sensor is still in place.
Plugs of doom must mean that there might ba a connection problem you mean?
Then it might be one of my soldering points from when I extended the loom?
#5 OneYet
OneYet
  • 1,354 posts
Crank sensor?
Where do I find this?
#6 techieboy
Posted 25 April 2012 - 07:59 PM
Maybe your soldering and definitely worth checking the throttle body but the loom of doom above the nearside drivers arch liner is the normal source of throttle related problems.
#7 OneYet
OneYet
  • 1,354 posts
Posted 25 April 2012 - 08:09 PM
I know there is a couple of big connectors behind the radiator tank. Is there some on the drivers side as well?
#8 techieboy
Posted 25 April 2012 - 08:12 PM
Ah sorry, drivers side, if your car is left hand drive. Yep, it's the connectors behind the expansion tank that usually cause problems. Normally just need cleaning up and making sure the female side of the connector is making good contact with the male side.
#9 OneYet
OneYet
  • 1,354 posts
Posted 25 April 2012 - 08:20 PM
WD40 or connectioncleaner spray, here I come.
#10 OneYet
OneYet
  • 1,354 posts
Posted 25 April 2012 - 08:21 PM
Crank sensor?
EERRHH. Never mind. I just used something called "search" and I found it.
#11 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 26 April 2012 - 04:51 AM
Sounds like the map sensor to me
#12 OneYet
OneYet
  • 1,354 posts
Posted 26 April 2012 - 05:21 AM
But that sensor is like 5 weeks old.
I will check the connections for it.
How do I check the MAP sensor itself?
Edited by OneYet, 26 April 2012 - 05:34 AM.
#13 smiley
Posted 26 April 2012 - 08:03 AM
Can you post a pixie of your SC. Especially the hosing on the SC actuator.
#14 OneYet
OneYet
  • 1,354 posts
Posted 26 April 2012 - 08:09 AM
The actuator is the black thing that doesn't look very hightech at all. Right?
#15 Exmantaa
5 weeks old sensor can still fail... You could measure voltages, but simply replacing with a (borrowed) new one is easier.
In Germany a few MAP's failed due to the heat of the inlet manifold and they sometimes mount these now "remote". (T-ed into the pressure regulator hose)
#16 chris_uk
Posted 26 April 2012 - 08:10 AM
only way to find out is fit another.
Edited by chris_uk, 26 April 2012 - 08:11 AM.
#17 smiley
Posted 26 April 2012 - 10:55 AM
Yes. It's where it's hoses go that might be of interest.
#18 OneYet
OneYet
  • 1,354 posts
Posted 26 April 2012 - 07:48 PM
Well. Plug of doom, TB plug and MAP plug has been flooded in contact spray. No luck. I did try to restart the car with the MAP senson unplugged and got the exact same result. But where can I get a sensor in Sweden? I read somewhere that it might be the same one in 1,7 cdti or something like that. Does anybody know? Pictures of the actuator are on their way Smiley. But I only have one tube on it.
Edited by OneYet, 26 April 2012 - 07:49 PM.
#19 vocky
Posted 26 April 2012 - 08:15 PM
1.7 cdti astra/corsa engine
Edited by vocky, 26 April 2012 - 08:16 PM.
#20 The Batman
Posted 26 April 2012 - 08:16 PM
:ninja:
