Can you do oil for the 2.2 supercharger?
Remind me, what kind of charger is it?
If it is the roots/eaton style charger then we tend to recommend the Fuchs Titan Race Pro S 5w-40.
Cheers
Guy
Posted 01 August 2012 - 01:22 PM
Posted 01 August 2012 - 01:55 PM
Posted 01 August 2012 - 07:53 PM
If anyone wants to take advantage of this but doesn't know what to order;
Fuchs titan supersyn 5W-40 - http://www.opieoils....engine-oil.aspx
I've got my service on the 15th, was the above suitible for an NA or turbo? I've got an NA.
Also, what brake fluid is recommended for road use? Doing a European Road trip in September, so bit worried about boiling my brake fluid around the Alps.
It's suitable for both. I've used it in my NA for the last three services. I've also performed some oil analysis which has shown minimal wear metal content so I have no problem recommending it to others.
Any DOT 5.1 fluid will do. There are also a few DOT 4 race fluids that people recommend - generally with brake fluid it's more important to have fresh fluid than high quality because heat will break down any fluid regardless of quality. Check the colour (should be clear not brown or black) and replace regularly - every two years or less.
Edited by Roastie ITR, 01 August 2012 - 07:54 PM.
Posted 03 August 2012 - 11:05 AM
Posted 03 August 2012 - 12:12 PM
Posted 03 August 2012 - 12:36 PM
Posted 03 August 2012 - 01:40 PM
Hi Oilman,
When does the clearance deal end? Am looking to order in the next couple of days.
Cheers
Posted 03 August 2012 - 01:55 PM
Posted 03 August 2012 - 02:07 PM
Posted 03 August 2012 - 02:40 PM
Posted 03 August 2012 - 08:03 PM
