Vxr Turbo V Standard
27 replies to this topic
#1 TurboTurkey
TurboTurkey
  • 220 posts
Posted 21 August 2012 - 05:03 PM
Being from a Nissan tuning background, 200sx's, I'm interested in tuning my recently acquired VXT. Back in the day, on the 1.8 200sx it was and easy upgrade to the T28 turbo from the 2.0sx later model. This would give better boost and hold the boost up to the limiter better than the standard tubby. My VXT has a pre cat removal pipe, and a VXR turbo and map, but I was just wondering what power hike JUST fitting the VXR turbo would give as a base line mod? I'm looking to get an exhaust next, and air box mod but wonder what sort of power I should be expecting now, and after these additions. Sorry for the ramble!! Dave
#2 Bumblebee
Bumblebee
  • 7,592 posts
Posted 21 August 2012 - 05:09 PM
Anything past 250hp and I think your clutch is on its limits although some peoples clutches have been known to be ok for 260Hp after this you need to start thinking about chargecoolers/intercoolers
Edited by Aimy, 21 August 2012 - 05:11 PM.
#3 Bumblebee
Bumblebee
  • 7,592 posts
Posted 21 August 2012 - 05:10 PM
I've been from standard,stage 2,3 and now 4 :)
#4 TurboTurkey
TurboTurkey
  • 220 posts
Posted 21 August 2012 - 05:14 PM
Yeah. I don't want to go massive power as I like it as it is (famous last words!!) But wondered how much extra the VXR tubby was worth on its own????
#5 Whiteboy
Whiteboy
  • 6,950 posts
Posted 21 August 2012 - 05:20 PM
Without a map on the car, you will not see much more than standard power. The vxr turbo runs cooler and is less likely to crack so a worthy upgrade. If you do want to tune the car in the future I would advise upgrading the chocolate thrust bearing. Steve
#6 smiley
Posted 21 August 2012 - 05:26 PM
#7 turboluca
turboluca
    Vxt specialise
  • 3,103 posts
Posted 21 August 2012 - 05:42 PM
It's ok ramble , As aimy said past 250bhp clutch can start slipping , VCR turbo will make vx quicker , but full exhaust an remap the way. Why don't you go see the Barron he's in southwales by me
#8 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 21 August 2012 - 05:44 PM
The VCR turbo is not as popular as the DVD turbo.
#9 turboluca
turboluca
    Vxt specialise
  • 3,103 posts
Posted 21 August 2012 - 05:58 PM
Rob there the new turbos out in south Wales lol.
Damm iPhone .Ha
#10 funbobby
funbobby
  • 298 posts
Posted 21 August 2012 - 09:23 PM
Would you notice much difference putting the VXr turbo before the map gets done if the original is a bit tired?
#11 Bumblebee
Bumblebee
  • 7,592 posts
Posted 21 August 2012 - 09:31 PM
I've heard there no difference but I'm sure someone will confirm the above
#12 TurboTurkey
TurboTurkey
  • 220 posts
Posted 22 August 2012 - 07:23 AM
What's the standard boost pressure on the VXT? Would not a bigger turbo flow more air at the same pressure, compared to the smaller standard thrbo, therefore giving slight better power?
#13 Nev
Posted 22 August 2012 - 07:30 AM
Yep, thats 1 of the 2 principle benefits of moving up in turbo size.
#14 Bumblebee
Bumblebee
  • 7,592 posts
Posted 22 August 2012 - 07:41 AM
Am I right in thinking standard boost is 0.8 bar?
#15 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 22 August 2012 - 08:21 AM
http://www.vx220.org...boost-pressure/
#16 Winstar
Winstar
  • 4,264 posts
Posted 22 August 2012 - 09:53 AM
yes but the flow characteristic isn't that differet between the two, the main advatage of the VXR turbo is that it's more efficient giving you a lower outlet temperature at the same boost pressure
#17 SteveA
SteveA
  • 9,159 posts
Posted 22 August 2012 - 10:01 AM
I was stage 3 for a year then I fitted a VXR turbo. IMO there is no noticable difference without some injectors and a remap. Then there is a BIG difference :)
Edited by SteveA, 22 August 2012 - 10:02 AM.
#18 TurboTurkey
TurboTurkey
  • 220 posts
Posted 22 August 2012 - 10:07 AM
Would a bigger VXR turbo get to the required boost pressure with less effort, therefore less heat etc but still the ecu would only allow 10psi or so. The extra power would Be gained when a map allows higher boost pressures and the turbo can 'manage' to hold it higher up the rev range ?
#19 Bumblebee
Bumblebee
  • 7,592 posts
Posted 22 August 2012 - 11:00 AM
Yep I agree :)
#20 TurboTurkey
TurboTurkey
  • 220 posts
Posted 22 August 2012 - 11:14 AM
What size are standard injectors, and at what power do they max out ?
