Vxr Turbo V Standard
27 replies to this topic
#21 Bumblebee
Bumblebee
  • 7,592 posts
Posted 22 August 2012 - 11:17 AM
Stage 4 requires vxr injecters so I presume stage 3 the limits??
#22 siztenboots
Posted 22 August 2012 - 11:34 AM
stage 2 is the limit on std injectors
#23 TurboTurkey
TurboTurkey
  • 220 posts
Posted 22 August 2012 - 12:03 PM
What duty cycle are they on at st2 etc as this would obviously be the limitin factor ?
#24 Bumblebee
Bumblebee
  • 7,592 posts
Posted 22 August 2012 - 12:15 PM
I was running stg 3 with standard injectors
Edited by Aimy, 22 August 2012 - 12:18 PM.
#25 SteveA
SteveA
  • 9,159 posts
Posted 22 August 2012 - 01:50 PM
:yeahthat: Me too, 265bhp MMG Stage 3.
#26 siztenboots
Posted 22 August 2012 - 01:59 PM
I maxed out the standard injectors, that was with a standard turbo and exhaust (including all cats), plus 3" 2bular backbox , that was on the dyno at Courtenay Sport, early in 2007 and with the target lambda you could see the injector duty maxed out at 25ms , ideally you want to be 20ms (approx 80%).
#27 TurboTurkey
TurboTurkey
  • 220 posts
Posted 22 August 2012 - 03:19 PM
I agree on the 80% cycle being best. Have seen higher though but that not good news. What power did u get at 80% ??
#28 siztenboots
Posted 22 August 2012 - 03:29 PM
We did not leave it like that as the ecu could not get target lambda ( i think 0.86 ) it just kept rising, put the standard map back on , then a few months later went back with a stage 3 chargecooler setup and fitted the bigger injectors.
