Throttle Cut Off - Diagnostic Code P1271
Posted 04 September 2012 - 01:27 PM
The engine light that has come on is giving the diagnositic code P1271 and from reading the following thread, it would seem it could be a throttle body issue or some loose wiring:
http://www.vx220.org...e-body-problem/
I see that this is something that people appear to have fixed themselves, but I'm not sure that I'm up to the job bearing in mind that:
- I don't know where the throttle body is or what it looks like (same for connecting wires)
- The car isn't in a garage - it is parked on a London street
- The most technical things I've done to it are demisting the rear light & changing a fuse for the cigarette lighter
Is this likely to be an expensive or difficult fix?
All help / guidance / pointers very gratefully received!
Posted 04 September 2012 - 01:30 PM
Posted 04 September 2012 - 01:31 PM
I'll try to find it....
eta
see if this sounds similar....
http://www.vx220.org...e-will-to-live/
Edited by Robski, 04 September 2012 - 01:36 PM.
Posted 04 September 2012 - 02:17 PM
Posted 04 September 2012 - 02:57 PM
Thanks FLD - I'm in Clapham in south west London .... if anyone is in the area that knows about it, then that would be very handy!!Typical loom of doom failure. Usually the two plugs behind the header tank. Where abouts are you apd-rock? Someone local might be able to help you.
Posted 04 September 2012 - 03:06 PM
Posted 04 September 2012 - 04:04 PM
Posted 04 September 2012 - 04:50 PM
Posted 04 September 2012 - 06:38 PM
Posted 04 September 2012 - 06:47 PM
I'm not long enough to bend over the car and go so deep as you.
Ooo er :/
50 shades of .org
Posted 04 September 2012 - 08:53 PM
When you were doing that, you didn't happen to take a picture did you? Not too keen on pulling out wires without knowing exactly what I'm looking for!Why do people take off the wheel and go in through the wheel arch liner?
Pop the clip off the header tank and move the tank to the side, then you can reach in, unclip them, pull them out and check them. I had this issue while away on a weekend and it was due to water getting into the plugs (no rear undertrays and a shed load of rain).
Opened them up, gave them a skoosh of WD40. was absolutely fine. Did the whole thing with a house key, no tools required.
Posted 04 September 2012 - 09:10 PM
http://www.vx220.org...y-wire-problem/
Post 20 has photos but the whole thread is useful.
R
Posted 05 September 2012 - 06:42 PM
Posted 06 September 2012 - 07:40 AM
Posted 06 September 2012 - 12:54 PM
It is mostly used for 'normal' driving, although don't use it on a daily basis. Only had two track days in it so far & both times the throttle cut out.It's odd you say it only happens on TDs. You do use the car from day to day?
First time was back in Feb, but when I restarted it said 'refill' and once refueled the problem didn't re-occur. At the time I thought that the cut out was fuel related, although don't think it was now. Mentioned it when I was getting serviced at Back on Track in June, but they didn't see anything unusual with it.
When it happened at the track on Saturday, I initially assumed it was fuel related but I still had about 1/2 a tank left. The light remained on, and the problem re-occurred about three more times at ever decreasing intervals so decided to cut short the day as the car was needed to get home! Drove back quite sedately, but it still cut out a few more times (on the motorway & in traffic).
Checked the light / OBD again on Monday and was getting the same error, but when checked it last night the light had gone off without me doing anything. So if I did clean the connectors, I'm not sure how I'd know if I fixed the issue!
Posted 06 September 2012 - 03:45 PM
Also tagged with one or more of these keywords: P1271, throttle body
General Discussion →
Off topic Chat →
I Broke Two Cars Within One Hour This MorningStarted by IWOOT , 27 Feb 2013 ![]() |
