Posted 27 February 2013 - 10:53 PM
Posted 27 February 2013 - 10:59 PM
Posted 27 February 2013 - 11:06 PM
Posted 27 February 2013 - 11:13 PM
Posted 27 February 2013 - 11:17 PM
Posted 27 February 2013 - 11:28 PM
Edited by IWOOT, 27 February 2013 - 11:29 PM.
Posted 28 February 2013 - 07:27 AM
Posted 28 February 2013 - 07:30 AM
Posted 28 February 2013 - 07:44 AM
Posted 28 February 2013 - 08:40 AM
Posted 28 February 2013 - 12:46 PM
Posted 28 February 2013 - 12:54 PM
Posted 28 February 2013 - 01:55 PM
You should have posted on here and waitied...i have a full set of shocks and springs from my old fiesta in the garage which are virtually brand new as i fitted coilovers
Glad you have it all sorted though
Fingers crossed you have no more problems with the loom of doom
I needed to pick the kids up after work and although they'd have fitted in the VX boot, the authorities would likely take a dim view of such activity. If I'd had more time, I'd have put a set of Eibach's on there but too late now! Thanks though.
By the sounds of it you are about 30 stone in weight and about 3 ft high if you broke a spring and banged your head twice on the steering wheel.
Have we met?!
The lady shall slap thee
There's nothing quite like a slap from a rotund dwarf. Don't knock it til you've tried it!
if it turns out not to be the 'loom of doom', but it most likely is, I have a spare z22se throttle body you can have for free
Thank you
Seriously, given it cleared up and ran fine then so quickly I strongly suspect the LoD behind the coolant tank. I suspect you probably had just gone over a bump or something similar, as that was pretty much always the trip on mine.
To clean them is no more than a 10-20min job and you would really struggle to do anything wrong. Just make sure that you give the contacts enough time to dry properly before reconnecting them.
Will do - I'll buy some contact cleaner and (after I've used it) will display it proudly next to my tube of Tiger Seal. True badges of VX ownership!
Thanks everyone.
Posted 28 February 2013 - 02:19 PM
Posted 28 February 2013 - 09:03 PM
i think the shocks i have have 35mm eibachs on them
Don't tell me that
Perhaps when I break one of the rear springs I'll drop you a PM!
Posted 01 March 2013 - 10:40 PM
at last! people have started not to use WD40!!!
Posted 02 March 2013 - 08:11 PM
when you coming to a meet again? not seen you since.... July?
Hi Stuwy. The VX didn't move that much over the winter because it was just too cold, I now have a hardtop and a Fezz heater, so I think I'm sorted on that score. If the March meet turns into a run, then I could be tempted out - be good to see your SC
Glad to see you're coming to Helmingham Hall in August - back to your Suffolk roots!
Edited by IWOOT, 02 March 2013 - 08:25 PM.
Posted 02 March 2013 - 08:29 PM
I would like to nominate this for post of the month.
Posted 02 March 2013 - 09:14 PM
Posted 03 March 2013 - 12:08 PM
Also tagged with one or more of these keywords: Bad day, p1271
General Discussion →
VX220 Discussion →
Throttle Cut Off - Diagnostic Code P1271Started by Pad-Rock , 04 Sep 2012 ![]() |
