Locked Out Of My Brand New Toy!
45 replies to this topic
#1 m5systems
m5systems
  • 208 posts
Posted 26 October 2012 - 12:13 PM
Fob not unlocking, key not unlocking passenger's side door, secret button not working. Pissed off! Any tips please peeps?
#2 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 26 October 2012 - 12:26 PM
First try the wd 40 in the key hole Guess the secret button battery has gone Try new battery in the fob Have a look on here as there is a way if getting in Without the secret button or a stanly knife But it's not public you have to pm one of the members who know
#3 m5systems
m5systems
  • 208 posts
Posted 26 October 2012 - 12:30 PM
Cheers - should the key still unlock then? It turns and depresses freely but just doesn't open
#4 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 26 October 2012 - 12:33 PM
Hardtop or soft top on?
#5 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 26 October 2012 - 12:45 PM
I thought the key holes where fake and unusable anyway? Is it a flat battery or another issue? If it's the battery and you're really stuck you can prod at the bonnet mechanism through the passenger wheel arch liner. That's only any good if you don't store the lock nut in it's holder though!
Edited by -Dab-of-Oppo-, 26 October 2012 - 12:48 PM.
#6 d4nnyk
d4nnyk
  • 769 posts
Posted 26 October 2012 - 01:02 PM
Key is useless in locks when central locking is fitted
Edited by d4nnyk, 26 October 2012 - 01:03 PM.
#7 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 26 October 2012 - 01:18 PM
crao forgot that
Looks like its half a breeze block then 😀
#8 m5systems
m5systems
  • 208 posts
Posted 26 October 2012 - 01:38 PM
cheers lads, apologies for the silence, but i managed to get into it so went out!! i noted that it turned over a little slower than ideal so need to be thinking about getting the bike optimate onto it for tricklicharging the battery i bet. i think its either that the keyfob batteries are low or possibly that its signal strength - i eventually got it unlocked and locked by holding the remote over the base of the wiper arm from outside - does anyone know where the sensor is for it? at least i know i can ignore that lock on the passenger side now! thanks
#9 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 26 October 2012 - 01:40 PM
Have you got a hard top or a soft top on the car? If soft top, either stretch, or just snip the cable and then you can get the roof off and you are in. or get a wire in there and wind down the window, should be easy enough as there is little resistance from the winder. if hard top, it may be possible to get to the electrics and put on a trickle charger :unsure:
#10 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 26 October 2012 - 01:42 PM
It might be worth having your own secret cig lighter socket ont he car, so should you ever need to charge it you can, down through the passenger front arch maybe?
#11 m5systems
m5systems
  • 208 posts
Posted 26 October 2012 - 01:51 PM
only soft top at the moment, thanks davemate, thats also a good idea about the charger - i think i will get a weather plug like from the motorbike and get that accessible but hidden from outside so that if i go out and its dead i can plug it in for a while been ages since i "enjoyed" motoring like this - am far too used to wondering out after 2 weeks of not using the motor and jumping into a heated leather seat with auto and cruise control to sleep up the motorway somewhere. still think its going to be worth it ;-)
#12 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 26 October 2012 - 01:52 PM
Good idea. Here is my solution - http://www.vx220.org...ndicator-panel/
#13 m5systems
m5systems
  • 208 posts
Posted 26 October 2012 - 02:17 PM
i thought you had something like that from looking at your pics - i am going to check if there is a car version of these - this one is motorbike so tiny terminals for the battery. am at the bike show in late nov/early dec so hope to get one for about a fiver! theyre inside a square centimetre of size at the business end so should be able to place it nicely
#14 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 26 October 2012 - 02:22 PM
Drive it enough, you will get used to driving the vx and then laugh at other cars and the things they dont need.
Glad to be of some help :)
#15 Kal
Kal
  • 285 posts
Posted 26 October 2012 - 02:33 PM
Secret button?
#16 m5systems
m5systems
  • 208 posts
Posted 26 October 2012 - 02:36 PM
er, its a secret, i'm not getting into trouble with the "bigger boys" on here whilst i am only a noob ;-)
#17 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
£4.49 on ebay. Those eyelets should fit on the smaller nuts that branch off the main terminals of the battery, if not you can just cut them off and crimp on bigger ones.
#18 techieboy
Posted 26 October 2012 - 02:39 PM
And replace the central locking backup battery that's in the boot. It sounds like your battery was getting near the too flat to do much state and it's probably a knackered backup battery continually drawing current from the main battery but, unable to store it.
#19 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 26 October 2012 - 02:40 PM
Secret button?
Hardly secret. It's the small black button inbetween the rear number plate lights on a C/L equipped turbo. It connects an additional small back up battery in the boot to enable you to unlock the car with the fob as normal in the event of your main battery going flat.
That's the theory anyway, most will have died by now. 3kg of pointless added weight IMO , I ripped mine out.
#20 siztenboots
Posted 26 October 2012 - 02:41 PM
I'd replace it with a setup of 8x rechargeable AA's , smaller and lighter
