Spitfire Rear Brace Kit
57 replies to this topic
#21 darronwall
darronwall
  • 2,706 posts
Posted 13 February 2013 - 06:57 PM
Looking forward to trying this out
#22 darronwall
darronwall
  • 2,706 posts
Posted 13 February 2013 - 09:44 PM
Many thanks for the bits we have for the car in Liam's,your help is much appreciated.!!!
#23 Spitfire Engineering
  • 755 posts
Posted 13 February 2013 - 09:58 PM
You are more than welcome :) Like them? Steve Guiglielmi has been running the same rod ends as main wishbone bearings on the 24hr race car for over two years and they are still stiff! Should have the trial brace ready within a week or two and the matching mounts shorly after. I believe Simon is planning to help Liam as the ARB is a bit of a black art to set up, i know he has already started work on the damper valving. Have a good evening. :) Gaz
#24 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 13 February 2013 - 10:02 PM
Will the new bar only work with the rear blade arb setup and/or can it be fitted with any other upgraded toe link kit?
#25 darronwall
darronwall
  • 2,706 posts
Posted 13 February 2013 - 10:11 PM
You are more than welcome :)/>
Like them?
Gaz
It all looks like a quality bit of kit,it will give me the piece of mind I want after seeing some failures on track with the standard items
I have the car at oulton on march first with Liam and at Caldwell on the 17 th,although I havnt driven Caldwell before so hope to get my eye in as well as messing with the set up
Thanks again
Edited by darronwall, 13 February 2013 - 10:16 PM.
#26 Spitfire Engineering
  • 755 posts
Posted 17 February 2013 - 08:31 PM
It doesn't need the rear ARB to be fitted, but as new inner mounts are used it is designed to work with the Spitfire kit.
From the feedback received so far I suspect the brace combined with the Cornering Force ARB and damper setup will prove to be the most effective suspension upgrade available for the VX family.
Gaz
Edited by Spitfire Engineering, 17 February 2013 - 08:33 PM.
#27 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 17 February 2013 - 08:36 PM
Gaz
Thanks for the info. I'm not going down the road of the CF set up.
I have the EP toe link kit. Will your brace bar fit with this?
#28 JG
JG
  • 13,615 posts
Posted 17 February 2013 - 09:41 PM
when can i have one?
#29 techieboy
Posted 17 February 2013 - 09:54 PM
I've still got my original Spitfire bracebar, if you want to see if it'll fit Nick? Had to remove it when trying to diagnose the "clunk" as the exhaust would bounce off it over bumps. Didn't solve the problem and still have the "clunk" though, so think I'll probably remove the Cornering Force rear ARB (and probably return the front to a regular ARB as well) and see if that solves it.
#30 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 17 February 2013 - 10:32 PM
Cheers Matt. I would like to take you up on that offer.
I remember the 'clunk' from the Le Mans trip :blush:
#31 techieboy
Posted 17 February 2013 - 10:42 PM
Yep, the same bloody clunk. :wacko:
The brace bar didn't fit on my car with the Milltek or the Piper exhaust systems at all. Got a bit closer with the Tullet system but it was never going to have sufficient room without spacing the diffuser off the subframe and clam and going for the "dragging my arse along the road" look that that gives.
#32 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 17 February 2013 - 10:52 PM
Will be interesting to see if it fits with my smaller Tullett as well as with the EP brackets
#33 Bumblebee
Bumblebee
  • 7,592 posts
Posted 17 February 2013 - 10:55 PM
I was maybe looking into purchasing this but looks like its a no go with me having a milltek exhaust
#34 Spitfire Engineering
  • 755 posts
Posted 18 February 2013 - 09:46 AM
Have you looked at the damper Nitrogen pressures?
Are you on Nitrons?
Have a chat with Simon@CF, pretty sure he has seen this before. Personally I would wait before taking the suspension to bits.
Gaz
#35 Spitfire Engineering
  • 755 posts
Posted 18 February 2013 - 09:52 AM
Gaz
Not sure what thread they use? if you have images of the entire inner fixing it would help.
Assuming it is the same thread the inner fixings/rod ends would be replaced.
#36 JG
JG
  • 13,615 posts
Posted 18 February 2013 - 09:55 AM
come ca
#37 Spitfire Engineering
  • 755 posts
Good decision, the original design is very unlikely to fit a Miltek as that was always the biggest issue, but it fitted over 80% of those trialed.
Anyway if you bought a used one it wouldn't be in purple then would it! :)
#38 Spitfire Engineering
  • 755 posts
Posted 18 February 2013 - 09:57 AM
come ca
Is this all EP or ES?
#39 JG
JG
  • 13,615 posts
Posted 18 February 2013 - 09:58 AM
ES :)
#40 Spitfire Engineering
  • 755 posts
Posted 18 February 2013 - 10:04 AM
Interesting, apart from the rods and bearings (the expensive parts) it looks like they copied almost everything else. Why is there no thread showing on the inner rod end? is it just out of focus? :)
