Right guys an girls am going to fit a new actuator to my stage 4 as my old one is making a tapping sound , bit tinny sound it is. Tried loosing it , but won't budge as its rusty .
How easy is it to fit an what shall I remove ?
6 replies to this topic
Posted 16 February 2013 - 10:13 AM
Posted 16 February 2013 - 08:39 PM
Nobody can help or have done similar
Posted 17 February 2013 - 09:12 AM
I'm still looking for advice or a member who has done this before thanks
Posted 17 February 2013 - 09:59 AM
start with the bottom nut on the wastegate lever. if you have the uprated cosworth one, two more nuts on the underside attach it to a special bracket, then lift free.
The original DZ actuators are attached to the standard bracket which is held on by the three recirc valve bolts.
Posted 17 February 2013 - 10:07 AM
It's stage 4 from courteaney , there's funny rattle like tinny sound so I tried loosing nuts they rusted on , so do I have to break it ?
Posted 17 February 2013 - 10:14 AM
not much in them, inside is a diaphragm and a spring. usually you get a split and it leaks.
Posted 17 February 2013 - 10:48 AM
Don't think it split . Causing it to rattle when no pressure on throttle an then goes away when throttle applied .
Had similar to my first stage 4, takes 1 hour to change roughly and you then have to set it .
Edited by turboluca, 17 February 2013 - 10:49 AM.
Also tagged with one or more of these keywords: Stage 4
General Discussion →
Tuning & Modifications →
Projects →
Project Pig Stage 3/4 BuildStarted by Andy_VX , 25 Jan 2017 stage 4, project, p16vxx |
The Market Place →
Cars For Sale →
Mandarin Vxt Stage 4 With Big SpecStarted by Vaux Pop , 20 Jun 2014 for sale, mandarin, stage 4 |
The Market Place →
Cars Wanted →
Stage 4 Vxt WantedStarted by Pazuzu , 05 Jul 2012 stage 4 |
