Cams For High Rpm?
camshafts high rpm Chrome-Moly
51 replies to this topic
#1 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 24 April 2013 - 01:22 PM
I need some 2013 advice on cams for a 'high' revving NA (7800rpm?). I'm currently running with a dbilas with a rather large throttlebody but plan to go ITBs.
I have Natrium-cooled exhaust valves in a Kokill casted head, a L61 Engine Block, Eagle Chrome-Moly Crankshaft, Eagle Chrome-Moly connecting rods, Wiseco Pistons (CR 8:9:1 ), Clevite Rod and Main Bearings bound together by ARP Head Studs. Fast road is with good torque is what I'm looking for. Here's some profiles that looks interesting
1. http://www.catcams.c...log/4603113.pdf
2. http://www.catcams.c...log/4603114.pdf
#2 techieboy
Posted 24 April 2013 - 01:23 PM
Bin your Wiseco pistons (or flog them to an SC'er) and replace them with higher compression versions, if you're planning on getting any NA power.
#3 oakmere
oakmere
  • 2,143 posts
Posted 24 April 2013 - 01:27 PM
Such low comp pistons will kill N/A power or dose the head gain it back. Alanoo was pushing over 8000 rpm on the Schrick.
#4 speedster
speedster
    Future of Speed
  • 3,600 posts
thumbsup Good point. Engine was original intended for an SC application.
#5 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 24 April 2013 - 01:29 PM
That's close to the limit. Some test data I've seen indicates the crank exits the engine at around 8200rpm.
#6 siztenboots
Posted 24 April 2013 - 01:32 PM
any good ?
Part # 88958620
Ecotec Crankshaft, billet steel
Internally balanced, full-race, billet 4130 steel crankshaft with
1.888" rod bearings and stock-size main bearings.
Reduced stroke of 3.505" for high RPM use.
#7 The Batman
Posted 24 April 2013 - 01:34 PM
Keep the pistons if you have already fitted them and skim the head
#8 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 24 April 2013 - 01:36 PM
any good ?
Part # 88958620
I'm OK for crank :P
Stroke reduced by the rods of crank profile?
#9 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 24 April 2013 - 01:39 PM
hmmm... Interesting.... have to take the head off so might as well as take it that step further and replace the pistons?
#10 oakmere
oakmere
  • 2,143 posts
Posted 24 April 2013 - 01:40 PM
Alanoo had the same issue an got low comp pistons by mistake. He skimmed the head by 1.4mm which is the max before you hit the oil restrictor. http://www.z22se.co....r-project.6314/
#11 The Batman
Posted 24 April 2013 - 01:45 PM
Might save time and money though..
#12 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 24 April 2013 - 01:51 PM
Building it myself so shouldn't be too much on an addition plus I can sell the Wiseco pistons (brand new) to recoup. Plus it's a SAAB head I have so I really don't want to mess with it coz no idea how it's going to preform.
Anybody know where I can pick up 11:1 pistons?
#13 techieboy
Posted 24 April 2013 - 01:53 PM
Cheap option is rods and pistons from a Z22YH engine (no idea how suitable they are from a strength point of view). Expensive option is to get some custom made as Vocky did.
#14 The Batman
Posted 24 April 2013 - 01:55 PM
The z22yh are meant to be good for 300 Not that you will make near that though so super safe for na! :lol:
#15 oakmere
oakmere
  • 2,143 posts
Posted 24 April 2013 - 01:59 PM
Just get the std 10:1 pistons and do a 0.75mm skim like I did. Should get you around the 11:1 mark.
#16 oakmere
oakmere
  • 2,143 posts
Posted 24 April 2013 - 02:04 PM
Also make sure you fit uprated valve springs. You will get float above 7200 rpm.
#17 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 24 April 2013 - 02:33 PM
I have some oem pistons which you can swap with me for your low comp ones :D seriously if you want standard you can have some which are in the shed, 30kish on them, just pay postage
#18 vocky
Posted 24 April 2013 - 02:35 PM
z22yh pistons and rods are the cheapest way to get 11:1 CR thumbsup
As for the cams, I think CompCams stage 3 are probably still the best available, the schrick are similar to stage 1 :unsure:
#19 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 24 April 2013 - 03:02 PM
thumbsup
thumbsup
thumbsup
thumbsup
#20 2-20
2-20
  • 1,317 posts
Posted 24 April 2013 - 03:13 PM
Please be advised that the CR advertised for Wiseco pistons is with a 1mm thick gasket. A Z22se or Z22yh head gasket is not 1mm thick
