Cams For High Rpm?
camshafts high rpm Chrome-Moly
51 replies to this topic
#41 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 25 April 2013 - 08:28 AM
does the gmpt-e15 scale up to these rpm , I thought most high rpm had gone webcon ecu.
I have a Emerald ECU for this engine but if I go itbs I will use the webcon alpha, maybe :P
#42 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 25 April 2013 - 08:33 AM
Keep the pistons if you have already fitted them and skim the head
Ok batman :) mulling it over.....looking at the engine..... ThIs suggestion is starting to make sense!
I need to skim off a millimetre, is that correct? Can I go further? Mill and a half?
If you skim too much the chain tensioner cannot cope and you need to fit a manually adjustable chain adjuster.
I have had the GM Racing oil pump gears fitted to my car for several thousand miles and have had no oil pressure problems yet.
My new 2.5 engine has a set of one off JE pistons which give a CR of 11.5:1
Ta! there's an engine machine shop near me, I'll drop the SAAB head over and have a chat. Where did you get the oil pump gears? What's the max compression ratio the engine can handle?
#43 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 25 April 2013 - 08:38 AM
I have some oem pistons which you can swap with me for your low comp ones :D
What pistons are you running if they're not low comp ones!
seriously if you want standard you can have some which are in the shed, 30kish on them, just pay postage :D
you can always sell low comp pistons.....
ok nick, I'll take them, just in case I don't go and skim. Will pm you.
#44 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 25 April 2013 - 08:40 AM
I have kept my std pistons. Good for 300 bhp so fine for N/A and no nasty piston slap! Don't think there is an issue with rpm up to 7800.
did you remove the balancers?
#45 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 25 April 2013 - 08:42 AM
My Z22yh rods and pistons are definitely good for 7600, probably more if you count the couple of times I've buzzed them on track days :huh:
You need 4032 alloy for after market pistons to allow a more OEM like bore clearance thus avoiding too much piston slap on a cold start up, problem is they cost £££££.
where did you purchase the z22yh rods and pistons! Got part numbers? :rolleyes:
#46 alanoo
alanoo
  • 1,324 posts
Posted 25 April 2013 - 10:16 AM
Does skimming so much off the head not have a detrimental affect on the squish?
it can but depends on what piston choice you made, afaik
It defintely does, but it is much cheaper than having special high compression pistons made
#47 oakmere
oakmere
  • 2,143 posts
Posted 25 April 2013 - 10:49 AM
Yes
#48 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 25 April 2013 - 11:55 AM
Maybe this thread could now do with a NSFW flag... Just glad my gaffer wasn't in while I read through page 2.
#49 siztenboots
Posted 25 April 2013 - 12:00 PM
fixed
#50 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 25 April 2013 - 01:18 PM
Sorry about that. I just got so revved up!
#51 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 25 April 2013 - 09:21 PM
Don't over rev about it, I am only running on single springs, so suffer premature float. :lol:
#52 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 25 April 2013 - 10:35 PM
:jump: :P
