I have some oem pistons which you can swap with me for your low comp ones
What pistons are you running if they're not low comp ones!
Posted 24 April 2013 - 03:35 PM
Posted 24 April 2013 - 03:49 PM
Please be advised that the CR advertised for Wiseco pistons is with a 1mm thick gasket.
A Z22se or Z22yh head gasket is not 1mm thick
Posted 24 April 2013 - 04:00 PM
Posted 24 April 2013 - 07:03 PM
Posted 24 April 2013 - 07:05 PM
Posted 24 April 2013 - 07:09 PM
Posted 24 April 2013 - 07:29 PM
Edited by oakmere, 24 April 2013 - 07:31 PM.
Posted 24 April 2013 - 07:32 PM
Alanoo had the same issue an got low comp pistons by mistake. He skimmed the head by 1.4mm which is the max before you hit the oil restrictor.
http://www.z22se.co....r-project.6314/
Posted 24 April 2013 - 08:03 PM
Posted 24 April 2013 - 08:50 PM
Mine has seen 8600 rpm on multiple occasions (and I have datalogs proving it), but I was generally putting the limiter at 8200 rpm on track
Posted 24 April 2013 - 09:16 PM
Keep the pistons if you have already fitted them and skim the head
Posted 24 April 2013 - 09:36 PM
Nop I got 10:1 pistons and skimmed 1.4mm
It's the bore that was wrong and fixed with a rebore.
Posted 24 April 2013 - 09:44 PM
I read somewhere that they are :
Z22yh gasket 0.37mm
Z22se gasket 0.49mm
Z20net gasket 0.98mm
http://www.z22se.co....r-sc-use.18077/
So you have about 0.5 more CR than advertised . Do you have standard size pistons or overbored ?
It also influence slightly the static CR
Posted 24 April 2013 - 10:08 PM
Thanks!Have you considered whether the oil pump on the Z22 will cavitate the oil at those sort of revs? I expect Vocky or someone will know. Looks like a lot of new bits in that engine. Good luck.
Posted 25 April 2013 - 06:27 AM
Posted 25 April 2013 - 07:49 AM
If you skim too much the chain tensioner cannot cope and you need to fit a manually adjustable chain adjuster.
Ok batmanmulling it over.....looking at the engine..... ThIs suggestion is starting to make sense!
I need to skim off a millimetre, is that correct? Can I go further? Mill and a half?
Posted 25 April 2013 - 08:01 AM
Posted 25 April 2013 - 08:06 AM
Posted 25 April 2013 - 08:23 AM
Posted 25 April 2013 - 08:25 AM
it can but depends on what piston choice you made, afaikDoes skimming so much off the head not have a detrimental affect on the squish?
