Most of the racing Elieses dont have Servo or ABS
Disabling Airbag And Abs Lights
#41
Posted 18 May 2013 - 05:53 PM
#42
Posted 18 May 2013 - 06:13 PM
any idea how they bias their brakes?
#43
Posted 18 May 2013 - 06:18 PM
I am sure they use a bias valve AP type , I will ask my mate who races in the Lotus Cup
#44
Posted 18 May 2013 - 06:22 PM
Cool, cheers
#45
Posted 19 May 2013 - 05:28 PM
None of the pre-Toyota engined Elises have servo's or ABS..
That only came in after 2004 when the first Toyota (2zz) powered S2 Elises came onto the market.
All (Rover) powered cars before that have used un-assisted brakes without ABS. It's what the car was designed for.
#46
Posted 14 July 2013 - 12:05 PM
Just had a quck eliminate of the airbag light (no seatbelts fitted) thanks to your info Jimmy. Useful trailblazing!
#47
Posted 14 July 2013 - 01:45 PM
Was the servo added and Is the master cylinder and rest of the system stay the same?None of the pre-Toyota engined Elises have servo's or ABS.. That only came in after 2004 when the first Toyota (2zz) powered S2 Elises came onto the market. All (Rover) powered cars before that have used un-assisted brakes without ABS. It's what the car was designed for. Bye, Arno.Most of the racing Elieses dont have Servo or ABS
#48
Posted 14 July 2013 - 04:13 PM
#49
Posted 14 July 2013 - 04:39 PM
Different MC was installed together with the servo and ABS.. Guess which one.. Correct! From the VX/Europa (which, as far as I know is the same as an Audi A3 MC?)
And after 2006 or so they also dropped the original extruded Elise pedals and went to VX style steel pedals as the pivot point for the brake pedal was less than optimal on the original pedals for the servo'd setup (it gave rather a large stroke and 'dead' range).
As far as I know is the non-assisted master cylinder on the Elise a 3/4"/19mm bore dual chamber (straight bore) cylinder. Don't know the MC size as used on the servo'd cars or the VX..
#50
Posted 14 July 2013 - 05:54 PM
Happy to help, I've had so many smart ass comments in this thread branding it useless so I feel partly vindicatedJust had a quck eliminate of the airbag light (no seatbelts fitted) thanks to your info Jimmy. Useful trailblazing!
#51
Posted 14 July 2013 - 10:40 PM
OK, I've guess I've been thinking, delete the servo but don't change anything else it's not going to match up very well.
Google VX220 master cylinder bore and found this on the first hit, so all good if you've gone bigger brakes all round.
I think I'll leave servo design for the OEM's! This is a race part, servo is dead wait and completely unnecessary if you aren't running ABS. FYI, the OE ABS master cylinder actually has a slightly bigger bore size than the motorsport one and works brilliantly with 4 pot front calipers and 2 pot rears.Has Hofmanns thought about designing a better servo?
#52
Posted 15 July 2013 - 08:39 AM
#53
Posted 15 July 2013 - 09:15 AM
#54
Posted 15 July 2013 - 09:35 AM
#55
Posted 15 July 2013 - 06:29 PM
So is there a need /market however small to need an abs to speedo interface unit?
That one is very simple...
http://jbperf.com/dual_VR/v2_1.html
Power, ground and signal from one of the hubs in, output pulse signal to ECU/dash out..
Done!
#56
Posted 15 July 2013 - 07:56 PM
#57
Posted 16 December 2017 - 09:29 PM
It seems a picture of JimmyJamJerusalemha disappeared. He explain how to remove the ABS light, but not the airbag one. Does anyone have the solution ?
#58
Posted 14 September 2018 - 12:08 AM
Same approach, but pin B.04 instead of B.12
