Stage 4 Acceleration
125 replies to this topic
#61 Bumblebee
Bumblebee
  • 7,592 posts
Posted 04 June 2013 - 12:54 PM
Did you get a boost and afr plot? Did the problem only arise after the dyno?
Edited by Bumblebee, 04 June 2013 - 12:55 PM.
#62 astravxr
astravxr
    Straight roads are for fast cars, turns are for fast drivers
  • 1,748 posts
Posted 04 June 2013 - 12:55 PM
I dont know what im running aimy, Liam said anywhere between 280 and 300. I would of thought he would of said that the boost control solenoid was buggered if it was?
#63 astravxr
astravxr
  • 1,748 posts
Posted 04 June 2013 - 12:56 PM
I didn't get anything, never had a dyno, Liam doesn't have one? There is no problem, he car has been the same since I got it back... Just not as fast as I expected
#64 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 04 June 2013 - 12:57 PM
What ideally do you want from all this power ?
Just to beat a astra on a motorway ?
#65 Bumblebee
Bumblebee
  • 7,592 posts
Posted 04 June 2013 - 12:58 PM
Sorry I was referring to lordmike. Yours (going by the vid) looks to be running as it should :) maybe you was expecting a little too much from it as I've been in a lot of fast cars and stage 4 isn't slow :)
Edited by Bumblebee, 04 June 2013 - 01:00 PM.
#66 astravxr
astravxr
  • 1,748 posts
Posted 04 June 2013 - 12:59 PM
L0rdMike that looks quicker than mine after 60 on low boost! Its after 60 I feel is slow. 0-60 is petfect
#67 Bumblebee
Bumblebee
  • 7,592 posts
Posted 04 June 2013 - 01:01 PM
I'd put it on a dyno just for piece of mind :)
#68 astravxr
astravxr
  • 1,748 posts
Posted 04 June 2013 - 01:02 PM
Yes i want to be super duper fast just to beat an Astra. No im only comparing the Astra 300bhp because i had one and ideally id like the vx to be faster
#69 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
James, take it back to Liams, get his view from a test drive.
Im shocked to even think a stage 4 cant keep pulling from 60Mph upwards 3rd/4th & 5th.
#70 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 04 June 2013 - 01:04 PM
I know when my intercooler pipe was loose and I was loosing boost, that made my car feel slow, even A-Monkeys SC stg2 almost pulled away from me...
Im guessing you fixed the air leaks ?
#71 L0rdMike
L0rdMike
  • 216 posts
Posted 04 June 2013 - 01:05 PM
Trying to compare the vids side by side, doesnt look much in it with yours looking slightly better off.
Im going to try another go tonight when it cools down a bit and see.
Edited by L0rdMike, 04 June 2013 - 01:06 PM.
#72 astravxr
astravxr
  • 1,748 posts
Posted 04 June 2013 - 01:06 PM
its hard to explain, it pulls just not as much as I thought it would with a light car with lots of BHP. After looking at that vid there looks to be a difference after 60, although I am looking at it on my phone
#73 Bumblebee
Bumblebee
  • 7,592 posts
Posted 04 June 2013 - 01:08 PM
Do you 2 not live close by? (Can't see on phone) might be good to have a pax ride if you do
#74 Bumblebee
Bumblebee
  • 7,592 posts
Posted 04 June 2013 - 01:10 PM
Yeah the Vx strong points are low to mid range if its more top end power your looking for I would of thought you need a bigger turbo to achieve this?
Edited by Bumblebee, 04 June 2013 - 01:10 PM.
#75 L0rdMike
L0rdMike
  • 216 posts
Posted 04 June 2013 - 01:11 PM
Whats the best way of checking for air leaks?
#76 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 04 June 2013 - 01:13 PM
Your almost 400 miles from me, must be other stg4 owners nearby
#77 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Southampton and the North East....
#78 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 04 June 2013 - 01:16 PM
My first popped off the lower intercooler pipe (IC side) that connects to lower part of turbo.
Had to upgrade the pipe work and clips.
Normal boost leaks are from the boost pipes splitting or popping off.
Normally a phy check, I think someone made (maybe Nev) a air pump to fill the system with air to check, Trying to find that post.
#79 astravxr
astravxr
  • 1,748 posts
Posted 04 June 2013 - 01:52 PM
Lower boost pipe kept coming off but I've sorted that out with stronger clips. I seem to always hit 20psi so shouldn't be a boost leak? Although Liam did say there was a turbo leak but probs because of the snapped stud. I will try sort this out and see if there is a difference
#80 astravxr
astravxr
  • 1,748 posts
Posted 04 June 2013 - 01:55 PM
The car always seems to stink of petrol, is this because of the decat?
