So I'm thinking about getting a VX220 again. (This one will be my 3rd...!) Only thing that puts me off is my lack of skill on recovering an unplanned fishtail - which was the last thing to happen to my VXR in the seconds before it was written off. I'm sure that the VX, being a mid-engined car only worsened the chances of me recovering the slides.
Now, I know about weight transfer and that kind of thing, and that the general concensus on the net seems to be that you should accellerate in the event of a fishtail, to get weight back onto the rear so the tyres can lock onto the road again.
However, the fishtail that killed my VX last time was caused by me accellerating in a straight line on a greasy motorway in about 3rd gear and spinning up the rear wheels. The revs rose and the sliding began. So in this scenario with the revs at about 4-5k, there seemed only one thing to do - back off the throttle to avoid the wheels spinning at an even faster rate and therefore giving even less grip(???). So in the brief seconds that I had to attempt to correct everythng, I came off the throttle and conscously gave fingertip-light inputs to the steering wheel to help the fronts keep as straight as possible - trying not to overcorrect, but all to no avail..!
So, question to those experienced MR drivers: in the situation where you get into a slide caused by spinning up the rears on full throttle, what do you do to recover it? Is it actually recoverable??
