High Compression Pistons - Anywhere?
high compression pistons where to buy
38 replies to this topic
#21 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 12:51 PM
About the Z22YH the CR is curiously advertised as 12:1 here and there
https://en.wikipedia...II_engine#Z22YH
And 11.3:1 for the 2.2 JTS used on Alfa-Romeo
JTS uses a different head doesn't it. Great if the pistons are compatible :)
#22 Rosssco
Rosssco
  • 4,185 posts
Posted 28 June 2013 - 12:59 PM
Not sure of the overall design fundamentally different, but it features direct injection so is not compatiable without modification.
#23 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 01:10 PM
Has the Z22SE block, wonder what the head profile is like. Just want the pistons so the DI ain't a problem. Though the rods and crank are probably Alpha specific.
#24 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 01:22 PM
reading...... direct injection has a different piston top profile so they are no good for the job.
#25 2-20
2-20
  • 1,317 posts
Posted 28 June 2013 - 01:42 PM
Both the 2.2JTS and the Z22YH use direct injection.
The Z22YH pistons are compatible (no combustion chamber in the piston as seen on others direct injection engines).
For the 2.2 JTS, i don't know.
#26 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 01:53 PM
Would be ok  but.... the Z22YH pistons needs the Z22YH rods.
#27 2-20
2-20
  • 1,317 posts
Posted 28 June 2013 - 02:21 PM
Yes but the Z22YH pistons and rods are heavier than the Z22se ones.
I've been told that you can re-use your Z22se rings and avoid a honing process
Edited by 2-20, 28 June 2013 - 02:22 PM.
#28 vocky
Posted 28 June 2013 - 02:45 PM
that is the info I also found when considering pistons, wiseco make custom 11:1 pistons to order and I have three spares sat in my shed. But you can only buy a set of four :glare:
#29 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 03:12 PM
have dropped them a mail. What compression you running vocky (your still NA aren't you?)
Edited by speedster, 28 June 2013 - 03:12 PM.
#30 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 02 July 2013 - 09:32 AM
From j-body.org
[color=rgb(0,0,0);font-family:Verdana, Arial, Helvetica, sans-serif;background-color:rgb(238,238,221);]Factory pistons from a Honda K20A have the same bore and wrist pin diameter. Compression height is about 3mm taller.[/color]
#31 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 August 2013 - 09:19 AM
according to the Mad Doc's calculations you can skim 1mm from the head to get 11:1 CR
or just use the 11:1 CR z22yh pistons and rods :sleep:
To quote a source
[color=rgb(0,0,0);font-family:arial;font-size:14px;]The z22yh DI pistons are drastically different from your typical pistons[/color]
Anybody know how they react to having a Z22SE cylinder head on top?
#32 techieboy
Posted 11 August 2013 - 10:01 AM
Hardly "drastically different".
Z22YH pistons ^^
#33 Winstar
Winstar
  • 4,264 posts
Posted 11 August 2013 - 10:47 AM
To quote a source
 [color=rgb(0,0,0);][font="arial;"]The z22yh DI pistons are drastically different from your typical pistons[/color][/font]
Modern direct injection pistons are but the YH was an early model so are pretty much normal pistons moral of the story don't believe anything written on an internet forum most people just regurgitate sh*t.
#34 vocky
Posted 11 August 2013 - 11:34 AM
I have built a few engines using the z22yh pistons and rods to raise the CR, they seem to work very well.
It's the saab 2.0 and later vvt pistons which have a different shape crown and are not really ideal.
Edited by vocky, 11 August 2013 - 11:35 AM.
#35 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 August 2013 - 01:14 PM
Good to hear. Where are you folk sourcing your [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:14px;]z22yh pistons and rods[/color]? Secondhand? New?
#36 vocky
Posted 11 August 2013 - 03:57 PM
secondhand z22yh blocks go for under £200, you can either swap the crank or swap the rods and pistons into your engine (you need to use the rods because they have a larger gudgen pin)
#37 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 August 2013 - 04:12 PM
Thanks vocky. What vauxhall models run with a [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:14px;]z22yh engine?[/color]
#38 vocky
Posted 11 August 2013 - 05:02 PM
2004> Vectra C or Signum use the z22yh engine and I believe the later zafira did too
#39 smiley
Posted 11 August 2013 - 05:34 PM
:yeahthat:  http://en.wikipedia....II_engine#Z22YH
Also tagged with one or more of these keywords: high compression, pistons, where to buy
