List Of Culprits - System Shutdown
21 replies to this topic
#1 Rosssco
Rosssco
  • 4,183 posts
Posted 09 July 2013 - 09:08 AM
Most strange, started up, drove down the road 100 yards, and the everything just switches off..
Pulled over (obviously), and no sign of stack / fuel pump or anything else giving signs of life.. Lights still work, as does alarm, so battery and connections appear good.. Key does nothing.
I presume its a connector / relay / fuse somewhere... (hopes)?
Cheers,
Ross
#2 smiley
Posted 09 July 2013 - 09:11 AM
1. Try your spare key first.
2. Press fuel cut off switch.
3. Remove fuse 8 for 5 min.
4. Verify battery + not touching chassis.
After that, it get´s more serious.
Edited by smiley, 09 July 2013 - 09:13 AM.
#3 Rosssco
Rosssco
  • 4,183 posts
Posted 09 July 2013 - 09:19 AM
Cheers Smiley, good list.. thumbsup
#4 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 09 July 2013 - 09:25 AM
Are you SC? If so make sure your alternator isn't shorting out on the inlet manifold.... Check ecu plug connections are not wet.
#5 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 09 July 2013 - 09:34 AM
Is it intermittent or terminal?
#6 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 09 July 2013 - 09:35 AM
He is.
#7 Rosssco
Rosssco
  • 4,183 posts
Posted 09 July 2013 - 11:05 AM
Jimmy, its currently terminal, only happened once so far.. I had to leave it and go to work.
I'll check the alternator connection, but I've made this mistake before, and in that circumstance the battery started shorting, which has not happended this time. The battery seems ok as there is still power to ancillary systems. I'll check ECU plugs. Been getting dead throttle syndrome recently, but sprayed the x2/3 connectors behind the header tank and that seemed to have cured it for the time being. Wonder if it could be related..
Or maybe this is a sign that my car really wants that LSJ engine upgrade after all.. :P
#8 smiley
Posted 09 July 2013 - 11:22 AM
If it´s going down that route again, ty down the cables to the bracket after respraying the connectors.
That will help in them moving less, thus less chance of shorting.
#9 Rosssco
Rosssco
  • 4,183 posts
Posted 09 July 2013 - 09:14 PM
Will keep that in mind Smiley, thanks. Well, done all of the above to no avail... However, I did check fuse 7 (ignition services -10A) and it was popped. Replaced it and the dash flickered as if about to start then popped again. Tried another 3 fuses and the same result of dead fuses... So, what would be causing it to continually pop fuses? I'll get some more tomo and give it another go Never tried a higher rated fuse, because I guessed it was rated as such for a reason..
#10 smiley
Posted 09 July 2013 - 09:34 PM
try picking Nick's brain for what happened 6 years ago.
http://www.vx220.org...ired-blown-fuse
led bulbs.
http://www.vx220.org...nt-start/page-2
#11 Exmantaa
Posted 09 July 2013 - 10:54 PM
Fuse 7 controls a lot, including an ecu connections and the starter relay...
http://www.speedster...ibution - 2.pdf
You have a ground shortage somewhere, so start checking that FB7 list...
(maybe your handbrake damaged the cable that runs right next to it?)
#12 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 10 July 2013 - 06:33 AM
Do you have a multimeter? Sounds like something is shorting to earth. Where are you based?
#13 Arno
Arno
  • 1,238 posts
Posted 10 July 2013 - 07:02 AM
Engine-to-chassis main ground strap broken/fractured?
#14 Rosssco
Rosssco
  • 4,183 posts
Posted 10 July 2013 - 09:02 AM
Cheers for the advise, I'll check some of these tonight..
Curious, I note fuse 7 is related to the radio / headunit, and I changed this just the night before this happened. Given the gaggle of wires in there, I could have easily broken / damaged one as I pushed the head unit in.. Worth a check tonight I think.
#15 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 10 July 2013 - 09:24 AM
Yeah defo mate if that intervention was immediately before the issue manifested then start there :)
#16 peteslag
peteslag
  • 919 posts
Posted 10 July 2013 - 09:44 AM
This could be a short to earth or a line to line short.  A good way to fault find is to set a multimeter to resistance, connect the black lead to a good earthing point on the chasis and the red lead into the circuit side of the fuse holder.  At this point a short to earth will give you a low reading (hence why your current is too high).  Then remove the head unit, if the problem is behind the stereo this will more than likely remove the short to earth and give you a much higher reading on the multimeter. If this happens you can then have a good look inside the dash and hopefully the culprit will present itself.  If not, PM me.  I have a wealth of electrical and electronic fault finding experience and I'm more than happy to help.
#17 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 10 July 2013 - 04:02 PM
Any joy bud?
#18 Rosssco
Rosssco
  • 4,183 posts
Posted 10 July 2013 - 07:40 PM
Well, thanks for the help on this. Took the replacement head unit out, and there was a loose exposed wire coming from the loom - perfect for shorting out under the dash. Pulled it off, replaced the fuse and it runs! Looks like this was what was happening (fingers crossed).. Ross
#19 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 11 July 2013 - 07:34 AM
Glad you got it sorted :)
#20 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 11 July 2013 - 07:52 AM
led bulbs.
I never got to find one cause for this, I checked the steering wheel and could find nothing, I did find that my loom had a load of cut wires where the extra ecu for the 5th injector was, these were just cut. Also he injector wiring was loose as it would run rough when I moved the loom near the injectors. Sadly was this the cause??????
Hope you find it though it did drive me mad worrying was it going to cut out,
