Sell It Whole Or Strip It For Bits?
#21
Posted 27 August 2013 - 08:10 PM
#22
Posted 27 August 2013 - 11:21 PM
Don't sell it while being at 99% Nick
The alternator for the post7k guys is a discussion on it's own, as the rpm's for the stock alternator pully is pushing it to the limits.
So these may fail more; this is unfortunately uncharted r&d teritory.
Get's Lee's alternator for now, and get you'rs refurbed. (it's difficult to get a new 100a, as the partnumber for the 100a and the 120a is the same, and some aftermarket 100a ones are the size of a 120, thus useless for us)
#23
Posted 27 August 2013 - 11:45 PM
#24
Posted 28 August 2013 - 04:51 AM
#25
Posted 28 August 2013 - 05:08 AM
cheers Joe, Lee for the parts offer and thanks all, came close yesterday let me tell you.
Just seemed strange it would pack up like that. I started the car and put it on the ramps (all OK), Unhooked the battery, removed the undertrays and checked the knock sensor.
I know I had to move some of the wires around the starter but I wasn't rough with it, then when I started it later battery light. I didn't notice though if it was on at the first start after messing with the knock sensor.
#26
Posted 28 August 2013 - 06:35 AM
#27
Posted 28 August 2013 - 07:53 AM
#28
Posted 28 August 2013 - 07:59 AM
you should check that the battery light plug is connected okay and that the big red cable is tight.
#29
Posted 28 August 2013 - 08:02 AM
I have an alternator Nic
Lee PM sent - not about alternator but boot lid
Cheers
Renny
#30
Posted 28 August 2013 - 09:25 AM
put up a for sale thread, show the car who is boss.
#31
Posted 28 August 2013 - 09:36 AM
Sell it at your peril... I will haunt you Nick if you do. I mean it!
#32
Posted 28 August 2013 - 10:52 AM
give it one last warning
#33
Posted 28 August 2013 - 12:18 PM
needed that Steve,
just found out I can't get the alternator out of the car, not through the top as the s/c is too big, not through the wheel arch as my swirl pot setup is in the way and not through the bottom as the cc/water pipes + starter are in the way. Now where is that big stick........
Think I will take the extra fuel pump/ swirl pot out. I checked the pressure today on a quick engine run and it is 3.4 bar not running bit low.
#34
Posted 28 August 2013 - 02:06 PM
#35
Posted 28 August 2013 - 02:14 PM
#36
Posted 28 August 2013 - 02:15 PM
#37
Posted 28 August 2013 - 03:05 PM
Sounds terrible. I'd get shot of it real cheap! PM on the way
#38
Posted 28 August 2013 - 03:25 PM
done, what a wonderful job
I removed the swirl pot and secondary fuel pump along with the fuel canister which was also in the way.
I think I might just replace the secondary pump now it's apart just to make certain the pressure it is suppling is ok.
#39
Posted 28 August 2013 - 06:05 PM
Pressure is regulated at the fuel rail regulator. If your pump can't cope with that @ idle, you have far bigger problems...
#40
Posted 04 September 2013 - 01:59 PM
Probably quicker to take charger of nick. Only 4 bolts! Remove intake pipe Remove belt Remove charger Alternator Then reverse! Job done
Understatement Joe let me tell you, I now put changing the alternator on a harrop s/c as PITA job.
just finished that now got to sort the fuel swirl pot out again
