Think Martin posted this in the wrong Traction Control discussion by accident...
http://www.vx220.org...-3#entry1656140
Should receive them soon...!
Posted 05 February 2014 - 02:22 PM
Posted 12 February 2014 - 01:38 PM
Received my filter safe and sound this morningGuys, you have a PM advising on delivery.
Posted 12 February 2014 - 06:11 PM
Received my filter today also
Posted 12 February 2014 - 06:37 PM
Edited by Westkenbrit, 12 February 2014 - 06:38 PM.
Posted 19 February 2014 - 08:00 AM
Posted 19 February 2014 - 09:32 AM
Posted 19 February 2014 - 10:04 AM
Posted 19 February 2014 - 10:10 PM
Posted 20 February 2014 - 07:30 AM
It's damaged, same with mine. Martin spoke to race logic and they want it sent back to repair it.Received mine today, the screen on the adjuster has a strange pattern on it. Not powered up yet, still in the packaging, has anyone else's got this?
Edited by Westkenbrit, 20 February 2014 - 07:47 AM.
Posted 20 February 2014 - 08:00 AM
Posted 20 February 2014 - 12:28 PM
Posted 20 February 2014 - 02:11 PM
Posted 20 February 2014 - 04:44 PM
Hmm, did some of you unpack the unit? LC displays are sensitive for electrostatic fields. Sometimes just rubbing the display with a plastic foil is enough to see such "active pixels" on an unpowered display. Probably the display is defect but I would have checked this before returning the unit.
Posted 20 February 2014 - 04:51 PM
Too late for me as I already sent mine back - But I would have thought racelogic would have asked us to do that before agreeing to replace them if it was a likely cause...?
I would have tried it if I had known though....
Yep - Agreed, Martin helped us sort the issue very quickly - Can't ask for more..!
Thanks Martin
Posted 24 February 2014 - 05:58 PM
Will these only work on the Turbo soft ware ? As there is no crank sensor delete on the CS VX220 2.2 software.
Posted 24 February 2014 - 09:11 PM
They use the abs wheel speed sensor, so should work on the 2.2Will these only work on the Turbo soft ware ? As there is no crank sensor delete on the CS VX220 2.2 software.
Posted 24 February 2014 - 10:32 PM
But may well trigger an EML from the built-in misfire detection (unless you've got the Dutch software and disable misfire detection) on the ECU.@kieran
Posted 25 February 2014 - 05:24 PM
Thats exactly what I have just been told .
Posted 25 February 2014 - 08:05 PM
My replacement arrive today.
Can't say fairer, they fixed the issue quickly.
Luckily I have the dutch software so can disable if needed, but that's blind luck… Surely if triggering a misfire EML was a material issue, it would be well known by now..?
There are enough people using it..?
Posted 25 February 2014 - 08:14 PM
My info came from CS just not compatible with Klassen VX220 2.2 soft ware at present no crank senor delete
Edited by kieranmcc, 25 February 2014 - 08:15 PM.
