Fuel Pressure Checking
46 replies to this topic
#21 siztenboots
Posted 26 September 2013 - 11:47 AM
compressing the bowl part of the tophat, increases the preload on the spring
fuel rail pressure is pushing up against the plate, and the spring + manifold pressure is push down against the plate
#22 Nev
Posted 26 September 2013 - 12:16 PM
Oh, are you using a non-OEM FPR? Ignore what I wrote then, if you are.
#23 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 26 September 2013 - 06:27 PM
oem but have a non oem I could use if required
#24 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 08:13 AM
Can't see what they could possibly do to the rail. Given the added complexity of your fuel system, I'm not even sure a comparison to my fuel system would be of much use. :wacko:
Just wanted to attach the gauge to you car to see what it shows, might be a gauge problem
#25 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 08:19 AM
Are you saying that your harrop can make 2.2 Bar of boost in the inlet manifold? That seems mega high to me Nick, AITs will be mental with prolonged use. :huh: You are certainly wise to lower the boost of 1.8 Bar (or perhaps even lower).   Did you ever install a meth/water spray kit BTW ? If so, what results did it produce please?
Yep 2.2 is a lot main, reason for the high IAT's on track I have the kit installed ready to go.
#26 vocky
Posted 27 September 2013 - 08:20 AM
I have a fuel gauge if you need another, am about today too
#27 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 08:21 AM
Great will check with SHMBO Any special time, wil bring the vx
#28 vocky
Posted 27 September 2013 - 08:23 AM
SHMBO says after 2pm
Edited by vocky, 27 September 2013 - 08:24 AM.
#29 techieboy
Posted 27 September 2013 - 08:29 AM
Pop up whenever, if you need to.
#30 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 08:35 AM
I will do both will nip to Matts to see if it shows the same pressure as mine in which case it's the gauge and will then nip over t you Neil to check how far out it is thanks
#31 vocky
Posted 27 September 2013 - 08:38 AM
a cunning plan :D
#32 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 08:43 AM
a cunning plan :D
Ahh but only if you pm me your post code I keep getting last, poor navigation skills..
#33 vocky
Posted 27 September 2013 - 08:45 AM
done thumbsup
#34 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 11:26 AM
Well that was interesting just been over to Techieboy and tried it on his car, 3.4bar (thanks for that)
I get 4.2 bar idle that has to be the 044 pump post swirl pot doing this. will go do some driving now to check how it is at higher rpm,
may not need to come over now Neil, seems to be my setup rather than the gauge.
#35 Exmantaa
Posted 27 September 2013 - 11:50 AM
Interesting...
3.4 bar is also not standard for a Z22SE, as that should be 3.8.
But your 4.2 base pressure should come down when the engine uses some fuel and is not overflowing your pressure regulator.
#36 vocky
Posted 27 September 2013 - 12:16 PM
sounds like too much pressure for the fpr to handle, might be time for a fuel rail upgrade to use a separate afpr
Just remove inner steel sleeve from the fuel rail and fit the afpr on the return line
Edited by vocky, 27 September 2013 - 12:16 PM.
#37 vocky
Posted 27 September 2013 - 01:17 PM
might be worth checking that the blue O ring seal is still intact, this should seal the fpr to the steel inner fuel pipe, otherwise you will not get any adjustment
#38 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 02:24 PM
gets even more interesting :huh:  just done some logging, will put then up on my project thread.
started off ok pressure was 4.2 static, when for a drive dropped down to 3.8 ok, booting it it ran up to 5.2 bit low I would have thought, then after a while it just sat at 4.2 regardless of where I put the throttle. i.e full chat 4.2 :wacko:  only thing I can assume is the secondary pump is packing up when hot
#39 FLD
Posted 27 September 2013 - 02:33 PM
I had an issue ages ago with a fuel pump.  Give the car a damn good thrash, it ran fine.  Turn it off to cool down and wouldn't re-start.  A little while later started fine.  Weird.  Turns out the pumps get hot, Turn off and the fuel cools the case.  The case gets too tight on the innerds and it essentially seizes.  Cools a bit more and it frees up again.  Could you be suffering something similar?
#40 FLD
Double penetration.
Edited by FLD, 27 September 2013 - 02:34 PM.
