Fuel Pressure Checking
46 replies to this topic
#41 techieboy
Posted 27 September 2013 - 02:40 PM
Well that was interesting just been over to Techieboy and tried it on his car, 3.4bar (thanks for that)
Interesting...
3.4 bar is also not standard for a Z22SE, as that should be 3.8.
Great. Now you've got me paranoid. :wacko:
Car hasn't been started for months and it was fine. Now it's been fired up and my fuel pressure is apparently too low. And you all wonder why I can't be arsed with it. :beat: :lol:
#42 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 27 September 2013 - 02:43 PM
Interesting...
That 3.8 figure is pump running engine off, yours if perfect, should be 3.3 idle
Edited by NickB777, 27 September 2013 - 02:43 PM.
#43 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 02:45 PM
I had an issue ages ago with a fuel pump.  Give the car a damn good thrash, it ran fine.  Turn it off to cool down and wouldn't re-start.  A little while later started fine.  Weird.  Turns out the pumps get hot, Turn off and the fuel cools the case.  The case gets too tight on the innerds and it essentially seizes.  Cools a bit more and it frees up again.  Could you be suffering something similar?
That's what I am thinking as well
#44 siztenboots
Posted 27 September 2013 - 02:49 PM
Interesting...
do you run a pipe from the FPR to the intake manifold ?
#45 techieboy
Posted 27 September 2013 - 02:50 PM
Yerrp. At least I do, anyway.
#46 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2013 - 02:53 PM
Yes
#47 Exmantaa
Posted 27 September 2013 - 05:14 PM
Ah, ok.
You normally check the base pressure with the regulator disconnected from the vacuum, but 3.4 @ idle vacuum sounds ok.
:sleepy:
