Mild Electric Shock When Battery Conditioner On
77 replies to this topic
#1 oakmere
oakmere
  • 2,143 posts
Posted 04 November 2013 - 01:18 PM
Whilst working on the car I noticed I got a mild electric shock when my face touched a metallic part it the car. I turned off the battery conditioner and it stopped. Should this be happening?
#2 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 04 November 2013 - 01:21 PM
The shock or rubbing your face on the car?
IMO neither should happen :lol:
Mine is on charge all the time and i have never been shocked touching any part of the car.
#3 oakmere
oakmere
  • 2,143 posts
Posted 04 November 2013 - 01:25 PM
I thought everyone did this? If I touched it by hand I didn't notice much but whilst climbing into the wheel arch my face made contact with the brake disk and got that tongue on a 9v battery feeling.
#4 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 04 November 2013 - 02:33 PM
My conditioner is a cetek and I have never had a problem
You wernt touching it with anything wet were you 😃
Edited by christhegasman, 04 November 2013 - 02:34 PM.
#5 ghand
ghand
    Drunken lampposts only
  • 9,215 posts
    Oh and more whisky
Posted 04 November 2013 - 02:55 PM
The charger only gives out a very low voyage 13/14 v and you can't feel that, more likely to be a little static possibly .
Edited by ghand, 04 November 2013 - 02:57 PM.
#6 slindborg
Posted 04 November 2013 - 03:57 PM
dodgy ground loop between the ring main and the car
#7 oakmere
oakmere
  • 2,143 posts
Posted 04 November 2013 - 05:29 PM
Yes sounds the most likely.
#8 vocky
Posted 04 November 2013 - 05:47 PM
mines exactly the same, usually when my head touches the rear diffuser  :beat:
#9 Nev
Posted 04 November 2013 - 06:14 PM
Are you plugged into 240v or 415v ?!
#10 Hammy of hamhouse
Hammy of hamhouse
  • 205 posts
  • Interests:Cars Hifi. Ex Westfield owner.
Posted 04 November 2013 - 06:22 PM
Check the plug wiring carefully and that the live / neutral on the supply are not reversed on the socket. Check the earth is ok too !
#11 oakmere
oakmere
  • 2,143 posts
Posted 04 November 2013 - 07:18 PM
It's not just me then Vocky! I will check the wiring on the mains side. It goes via an extension cable which may have a faulty earth. Forgot the multimeter tonight so will check tomorrow. I have never noticed this untill recently so assume it is a fault of some kind.
#12 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 04 November 2013 - 08:09 PM
:yeahthat: And besides metal parts on the car are likely to be ground anyway. If you got a shock some dodgy wiring somewhere.
#13 slindborg
Posted 04 November 2013 - 08:35 PM
1stly electrically for the car the world would have ended and secondly even if that was the case it wouldn't give you a shock. Yes the car is 12v but when connected by a potentially dodgy mains setup I to the ctek you might be offsetting the 'ground' of the car to give you a shock, it not killing the car as its still only a 12v system
Edited by slindborg, 04 November 2013 - 08:35 PM.
#14 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 04 November 2013 - 08:44 PM
Unlikely I would have thought of mixing live and neutral would have affected the output.
#15 higgins
higgins
  • 126 posts
Posted 04 November 2013 - 08:50 PM
having live and neutral reversed is of no consequence as it is ac. problem is with the conditioner.
#16 deano01
deano01
  • 1,480 posts
  • Interests:Playing with chainsaws and other power tools, Films, rallying, fishing, Vx
Posted 04 November 2013 - 09:00 PM
Can you post a video clip of this happening please. :lol:
#17 slindborg
Posted 04 November 2013 - 09:31 PM
Really.... Really..... And you of all people think that's true. Oh my. The charger is dc, its powered from the mains. The dc going into the battery will have the ground derived from the mains, now if there is something screwy with your home mains say having a bias in the neutral then you could raise the car ground to something which would tingle. Ether the charger is naffed or the mains has an issue.
#18 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 04 November 2013 - 09:42 PM
Seriously? If the mains is anyway connected to ground I'll eat your balls.
Chances are its a switch mode power supply. Or it is old school then bridge rectified. The ground will be isolated from the mains. Most appliances will still work of live and neutral are swapped. It just becomes less safe.
#19 higgins
higgins
  • 126 posts
Posted 04 November 2013 - 09:45 PM
its the charger, nothing to do with the mains
#20 slindborg
Posted 04 November 2013 - 09:56 PM
So, pray tell, where does the charger derive its '0v/ground' from then...... Do we atleast agree its not that the 12v and ground have been swapped magically :lol:
