Mild Electric Shock When Battery Conditioner On
#21
Posted 04 November 2013 - 10:00 PM
#22
Posted 04 November 2013 - 10:09 PM
there will be no ac earth on these sort of appliances as they are doubley insulated. my guess is it is the rectifieror a dodgy capacitor
#23
Posted 04 November 2013 - 10:11 PM
I will measure mine and see what it's kicking out
#24
Posted 04 November 2013 - 10:24 PM
Edited by vocky, 04 November 2013 - 10:25 PM.
#25
Posted 04 November 2013 - 10:26 PM
#26
Posted 04 November 2013 - 10:31 PM
#27
Posted 04 November 2013 - 10:55 PM
#28
Posted 04 November 2013 - 10:56 PM
Implying the dc ground has to be derived from the a.c earth is still just plain wrong though.I, ah, thank you
#29
Posted 04 November 2013 - 11:20 PM
#30
Posted 05 November 2013 - 12:19 AM
#31
Posted 05 November 2013 - 06:10 AM
So, pray tell, where does the charger derive its '0v/ground' from then...... Do we atleast agree its not that the 12v and ground have been swapped magically
Mains inlet is probably only magnetically coupled to the rest of the circuit via a transformer. So not electrically connected.
#32
Posted 05 November 2013 - 10:25 AM
I agree , I will go with your switch mode power supply output circuit filter theory, slight ac ripple on the dc Oh and it could be a high frequency ripple so forget what the multi meter says, or is that just made up rubbishMains inlet is probably only magnetically coupled to the rest of the circuit via a transformer. So not electrically connected.So, pray tell, where does the charger derive its '0v/ground' from then...... Do we atleast agree its not that the 12v and ground have been swapped magically
Edited by ghand, 05 November 2013 - 10:30 AM.
#33
Posted 05 November 2013 - 11:51 AM
I reckon it's a raspberry ripple Gordon.
Check the freezer.
#34
Posted 05 November 2013 - 11:58 AM
add a ground strap to the chassis?
#35
Posted 05 November 2013 - 12:18 PM
I reckon it's a raspberry ripple Gordon. Check the freezer.
#36
Posted 05 November 2013 - 05:51 PM
#37
Posted 05 November 2013 - 06:36 PM
When the circuit is made, neutral will not be at 0 volts. And any design of mains to DC supply will have to be isolated for safety reasons.
#38
Posted 05 November 2013 - 07:16 PM
#39
Posted 05 November 2013 - 08:28 PM
Wtf vocky? Capacitors pass Ac. Are you sure about that? Typically the dc side is derived from the output of the transformer then it is totally 'electrically' isolated. Only magnetically coupled.
#40
Posted 05 November 2013 - 08:44 PM
there is a wire on the PCB coming from the neutral terminal which goes to a capacitor, which then connects to the 0v of the output (DC)
I will take a picture
Edited by vocky, 05 November 2013 - 08:45 PM.
