Chaps!!!
I am finally going to take the plunge and get my NA engine built up properly (Z22se)
Question is, do i go for NA or Forced induction? Is switching to a 2.4 TB / Cams going to be satisfying enough?
Webcon TB's still worth a go?
Vocky, i think you were experimenting with modified firewall to get extra length on the TB trumpets? Any joy?
The engine will be 100% balanced / blueprinted / Ported / strong internals etc etc. so should rev to 7500 safely i'm guessing
I reckon a Rotrex charger would be ideal in terms of packaging and performance, but i'm concerned about mapping...
Can Courtenay's do it? Will they do it? Anyone else? Is there a piggyback ECU solution?
Can anyone shed light on whether or not the standard Siemens ECU has the ability to work with a Rotrex?
(I don't see why not really, if it has enough to work with the Eaton type?)
Don't really want to shell out for the full GM supercharger kit, but perhaps it's more cost effective in the long run?
Any thoughts / advice appreciated, very open to other's ideas!
Cheers
