P1271 Error Code, App Sensor Knackered
#21
Posted 14 March 2014 - 11:45 AM
#22
Posted 14 March 2014 - 12:04 PM
#23
Posted 14 March 2014 - 12:10 PM
#24
Posted 14 March 2014 - 12:34 PM
I'll pop round and we can both watchWell seen as its outside our lasses house it would be hard not to help
or maybe sit on the bench and watch you lol.
#25
Posted 14 March 2014 - 01:18 PM
Cheers slindy. Although everything seems to be pointing towards the APP sensor at the moment. Will go through all the other points mentioned before forking out for a new one though.£10 says its not the throttle pedal remove (CAREFULLY!!!!!) the plugs on the ECU and check for corrosion. there have been cases where the pins corrode off completely so watch out.
#26
Posted 14 March 2014 - 01:20 PM
You are too kind sirI'll pop round and we can both watchWell seen as its outside our lasses house it would be hard not to help
#27
Posted 14 March 2014 - 07:00 PM
Bring some cans then
#28
Posted 15 March 2014 - 04:53 PM
Quick update. Ivan helped me out with his OBD II and proper electrical contact spray. He managed (where me and Steve failed) to prize apart the black loom of doom connector. There was definite signs of corrosion around couple the pins so cleaned and magic sprayed them. Re cleaned the blue connector and throttle body connector then once more into the foot well and did the accelerator pedal connector again, all with the contact cleaner spray. Ivan cleared the fault code and it started, and accelerator worked. Turned if of and on several times, still worked. Success
Ivan followed me home and the EML came on but no limp mode . Cleared it again. Currently having a cuppa while typing this then going out for an hour to see what happens.
Definitely seems contact related. Will report back.
#29
Posted 15 March 2014 - 06:13 PM
#30
Posted 15 March 2014 - 07:01 PM
So, just back from a blast. Warmed it up, took it to the red line in every gear up to 4th. Tried sudden throttle inputs to try and trigger the fault. So far, so good...
Team Crab-Acid-Booze FTW!
#31
Posted 15 March 2014 - 07:08 PM
#32
Posted 15 March 2014 - 07:35 PM
Find a small pot hole and drop a wheel in it. If it doesn't trigger the fault then you should be good.So, just back from a blast. Warmed it up, took it to the red line in every gear up to 4th. Tried sudden throttle inputs to try and trigger the fault. So far, so good... Team Crab-Acid-Booze FTW!
#33
Posted 15 March 2014 - 08:00 PM
You figure out what had been done to the wiring at the black and blue connector in engine bay?
#34
Posted 15 March 2014 - 08:18 PM
#35
Posted 15 March 2014 - 08:37 PM
Just sorted out a load of tools to take down our lasses after not having much available the other day.
#36
Posted 15 March 2014 - 08:47 PM
#37
Posted 15 March 2014 - 09:01 PM
#38
Posted 15 March 2014 - 09:33 PM
#39
Posted 15 March 2014 - 09:39 PM
#40
Posted 15 March 2014 - 10:02 PM
