P1271 Error Code, App Sensor Knackered
#41
Posted 15 March 2014 - 10:19 PM
#42
Posted 18 March 2014 - 01:28 PM
So, after Steve plugged his OPCOM in there is good and bad news:
Good - The P1271 error code seems to have done one and the accelerator is behaving itself . Must have been the connectors
Bad - The EML came on this time because of error code P0140, 'O2 sensor circuit open, bank 1, sensor 2'. Steve cleared it and hasn't come back on yet. It only came on in the first place under extreme provocation. Anyone have any ideas what may be causing this?
#43
Posted 18 March 2014 - 02:11 PM
#44
Posted 18 March 2014 - 03:38 PM
Post cat lambda sensor gone tits up
#45
Posted 18 March 2014 - 03:48 PM
#46
Posted 18 March 2014 - 10:48 PM
#47
Posted 20 March 2014 - 03:35 PM
#48
Posted 20 March 2014 - 04:03 PM
#49
Posted 20 March 2014 - 04:07 PM
if its cold related , then exhaust manifold / gasket , small air leak
#50
Posted 20 March 2014 - 04:16 PM
#51
Posted 20 March 2014 - 04:18 PM
#52
Posted 20 March 2014 - 04:20 PM
#53
Posted 20 March 2014 - 04:59 PM
#54
Posted 20 March 2014 - 10:58 PM
More thoughts:
1) Temperature has been running at 95-97C when at 70mph for several weeks now. Used to be rock solid 89C. Goes back down to 91C at town speeds.
2) Slight misfire at low revs when cold.
3) EML pointing to lambda sensor.
Could all of this be pointing to the lambda sensor?
#55
Posted 20 March 2014 - 11:02 PM
I'd say yes, if it's running lean because of false lambda readings it will make the engine hotter.
#56
Posted 20 March 2014 - 11:19 PM
#57
Posted 20 March 2014 - 11:21 PM
Edited by fezzasus, 20 March 2014 - 11:28 PM.
#58
Posted 20 March 2014 - 11:32 PM
Bank 1sensor2 is the post cat sensor and as far as I remember doesn't have any influence on the fuelling it's a check for how well the cat is working. So not sure how that would be causing lean running. Knowing the luck you have with your car you may have multiple problems.Doesn't that run through the black plug of the two loom of doom connectors? May be we disturbed it when fiddling. Bit of a coincidence it happening straight after we where in there. On the up side that sensor doesn't affect the running as far as I am aware.
#59
Posted 21 March 2014 - 02:49 PM
I think, after taking everyone's advice and after much consideration I am going to carefully bury my head in the sand and pretend everything is just fineBank 1sensor2 is the post cat sensor and as far as I remember doesn't have any influence on the fuelling it's a check for how well the cat is working. So not sure how that would be causing lean running. Knowing the luck you have with your car you may have multiple problems.Doesn't that run through the black plug of the two loom of doom connectors? May be we disturbed it when fiddling. Bit of a coincidence it happening straight after we where in there. On the up side that sensor doesn't affect the running as far as I am aware.
Edited by Acidpopstar, 21 March 2014 - 02:50 PM.
#60
Posted 21 March 2014 - 02:50 PM
Might want to consider this route: http://www.vx220.org...ement-guide-na/
I would also strongly suggest systematically going through all the connections on the car, inspecting and repairing damaged wires and cleaning the contacts. You have already found the blue and black connectors with problems, and the throttle pedal connector. There will probably be others.
Edited by fezzasus, 21 March 2014 - 02:51 PM.
