P0141 O2 Sensor Replaced
Posted 17 March 2014 - 03:33 PM
Posted 17 March 2014 - 03:46 PM
Posted 17 March 2014 - 03:54 PM
Posted 17 March 2014 - 03:55 PM
this code also comes up with a cracked exhaust
Posted 17 March 2014 - 04:22 PM
Posted 17 March 2014 - 04:32 PM
Posted 17 March 2014 - 04:37 PM
I did think that as it just looks for a difference between the 2 sensors. Your manifold is probably cracked anyway though, they all areA crack in the manifold shouldn't trigger a P0141 error though. It should/would trigger an emissions related fault code but not a P0141 which only relates to the heater function in the lambda.
Posted 17 March 2014 - 04:50 PM
heater circuit = fcuked wiring/fuse/sensor.
Even replacement OEM sensors can be shite.
There is another solution coming soon... I did some soldering
Posted 17 March 2014 - 04:53 PM
Whoopheater circuit = fcuked wiring/fuse/sensor. Even replacement OEM sensors can be shite. There is another solution coming soon... I did some soldering
Posted 17 March 2014 - 05:02 PM
Posted 17 March 2014 - 05:03 PM
Posted 17 March 2014 - 05:04 PM
Wire a resistor in there, just not a cheapo Ebay one lol (its an 'in' joke!)
Posted 17 March 2014 - 05:06 PM
Indded, we dont want a thermal event
CPC is the cheapest place I've found to get a proper 15R 25+W aluminium resistor (without buying lots of the buggers)
Posted 17 March 2014 - 05:08 PM
Posted 17 March 2014 - 05:11 PM
15-20R (maybe 25 at a push) seems to be the norm. much outside each end starts to casue spurious errors.
Posted 17 March 2014 - 08:34 PM
Posted 17 March 2014 - 08:38 PM
Posted 18 March 2014 - 08:04 AM
Posted 18 March 2014 - 08:11 AM
You can usually tell because one is dirty inside and the other is clean.
thats the easiest way to tell
Also think mine are opposite threads
they are the same and it's easy to connect to the wrong one.
