Brand new one ready to go on (if I ever get around to starting this , or more importantly, I am actually capable of finishing it)
Diy Sos
#21
Posted 15 May 2014 - 01:57 PM
#22
Posted 15 May 2014 - 02:03 PM
You can do it, it's easy really. I casually did one a couple of weekends ago in 30 hours or so. start to finish.
#23
Posted 15 May 2014 - 02:05 PM
I would imagine your spannering skills are a little better than mine Tom
Fancy casually doing mine then Only kidding. Pretty sure I have a good idea, just need to ask some questions from time to time that's all
#24
Posted 15 May 2014 - 02:09 PM
all I'd say is:
1. Make sure the bolts at the bottom of the boot come out
2. Strip all the loom tape off the wiring loom and locate the connectors where you want them, you'll see you only need to extend five wires in total (three injectors one on the MAP, one on the fuel vent). Just cutting and extending without seeing if there's enough length already will introduce more points of potential failure.
#25
Posted 15 May 2014 - 02:12 PM
Thanks mate
Had the clam off a few times, so hoping all bolts should come out fairly easily. Going to sort the CC and pipe work this weekend and hopefully do it in stages.
Think I have just about every guide and image printed off in a folder ready, as am prepared
#26
Posted 18 May 2014 - 04:24 PM
Relatively productive day, despite some stubborn bolts. Had to cut these off, including the the two at the front and bottom of the clam (the bolts that screw in horizontally towards the outside of the car). For anyone that has had to cut these (the plate they screw into was spinning, so next to useless) how did you re-secure these when the clam goes back on?
#27
Posted 19 May 2014 - 07:23 AM
Jack nuts.
#29
Posted 19 May 2014 - 08:24 AM
Perfect thanks. Assume these work in a similar way to cavity fixings for plasterboard walls!?
#30
#31
Posted 19 May 2014 - 08:47 AM
Thanks Steve.
Guess they are all much of a muchness. Pretty much consumable items at their price anyway
#32
Posted 01 June 2014 - 11:22 AM
The one on the offside is virtually impossible to get at due to brake lines (and some bright spark thought Phillips headed bolt was a good idea)
Thanks
#33
Posted 01 June 2014 - 11:36 AM
Small ratchet with a philips head.
#34
Posted 01 June 2014 - 11:42 AM
#35
Posted 01 June 2014 - 11:45 AM
The bolts go into c clips so worst case you can dremel them off.
I didn't refit the one under the brake servo because life's too short.
#36
Posted 01 June 2014 - 12:30 PM
#37
Posted 01 June 2014 - 01:10 PM
#38
Posted 01 June 2014 - 01:11 PM
Just had a look at mine, assuming you're working using the same halfords kit as most people you'll need the small ratchet, small extension bar, adaptor for the screw heads and a large cross head. That should do it.
#39
and probably a tea while the penetrating oil does its job.
#40
Posted 01 June 2014 - 01:27 PM
